| Execution flow does not show anything [message #100877] |
Wed, 13 June 2007 08:00  |
Originally posted by: raduciora.yahoo.com
Hi there,
I'm trying to profile a java web application which sits on top of tomcat
5.5.20.I'm using jdk1.5.0_12, eclipse 3.2.1 and TPTP 4.2.0.2 and the agent
controller for TPTP 4.2.0.2.
After profiling I can open the Execution Statistics with no problem and the
same goes for the Coverage Statistics.
Problems:
1 When I open the Execution Flow view I cannot see any flow diagram. The
view opens fine but there are no bars showing.
2 In the Profiling Monitor view, when I select the monitor and I right-click
on it and select Open With , there's no Execution Flow entry(as the manual
says).
The way I open the Execution Flow view is by Eclipse's menu: Window->Show
View->Other... and from Profiling and Logging I select Execution Flow.
Am I doing something wrong?
Radu.
| Re: Execution flow does not show anything [message #100921 is a reply to message #100906] |
Wed, 13 June 2007 16:07  |
Hi Cindy,
No I din't do that. It should probably do it.
Thanks a million Cindy.
"Cindy Jin" <cindyjin@ca.ibm.com> wrote in message
news:f4pe0e$hgq$1@build.eclipse.org...
> HI Radu:
> When you created the profile lunch configuration, did you select the
> Execution Time Analysis->Edit Options->check the radio button for "show
> execution flow graphical details"?
> Thanks
> Cindy
> exquisitus wrote:
>> Hi there,
>> agent controller for TPTP 4.2.0.2.
>> the same goes for the Coverage Statistics.
>> Problems:
>> right-click on it and select Open With , there's no Execution Flow
>> entry(as the manual says).
>> Thanks,
>> Radu.
FUDForum. Page generated in 0.03765 seconds
