Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [OCLinEcore] Validation of OCL constraints
[OCLinEcore] Validation of OCL constraints [message #1008654] Wed, 13 February 2013 07:44 Go to next message
I am creating some OCL validation rules on my meta-model using OCLinEcore. I followed what is described on this page but the @extends annotation described there doesn't do exactly what it is "supposed" to do: it doesn't make the generated class extend OCLinEcoreEObjectValidator but instead it makes implement it (although it is a class and not an interface), which ends up in a compilation error (you have to manual correct the file to fix the problem at each generation of the model code).
Additionally, I was trying to have custom error messages when my OCL rule fails and followed the syntax described here. This works fine, since my custom message is displayed but the error is now a warning. Is this normal ?
On a side note, I am using GMF to create instances of my domain model.
Thanks.
Re: [OCLinEcore] Validation of OCL constraints [message #1008662 is a reply to message #1008654] Wed, 13 February 2013 08:43 Go to previous message
[Please use the OCL newsgroup for OCL discussions.]
Thanks for pointing out the @extends problem. I forgot the subtle
dufference here for "@generated NOT" and "@generated not". See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=338507.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=400683 raised to correct
the example and documentation.
See
http://help.eclipse.org/juno/topic/org.eclipse.ocl.doc/help/CompleteOCLTutorial.html?cp=46_3_2_3_5#custommessages
for details on message severity.
Ed Willink
On 13/02/2013 12:44, Cedric Moonen wrote:
> Hello,
> http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.ocl.doc%2Fhelp%2FPivotProgrammersGuide.html&anchor=OCLinEcoreEObjectValidator
> http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.ocl.doc%2Fhelp%2FIntegration.html&cp=42_1_7_1&anchor=Integration-Messages..
> Thanks.
Previous Topic:[Texo] Charset conversion errors inside xpt and xtend files
Next Topic:Texo: Auditing feature
Current Time: Sat Jul 26 02:12:00 EDT 2025
Powered by FUDForum. Page generated in 0.08209 seconds
