[CDO] Event to notify object has become dirty [message #1007873] |
Thu, 07 February 2013 15:37  |
Hi!
I'm currently using a listener attached the cdoView of my object that updates some objects when the cdoState of my object changes. I receive CDOViewInvalidationEvents for when a passive update makes my object conflicted and CDOTransactionFinishedEvents for when the object is clean after a successful commit. Is there an event I can use to determine that it has become dirty?
Thank you in advance!
Edit: Found a better solution by using this:
cdoView.addObjectHandler(new CDOObjectHandler() {
public void objectStateChanged(CDOView view, CDOObject object,
CDOState oldState, CDOState newState) {
System.out.println("Object: " + object.toString()
+ " transitioned to " + newState);
[Updated on: Thu, 07 February 2013 16:08] by Moderator
Re: [CDO] Event to notify object has become dirty [message #1007989 is a reply to message #1007873] |
Fri, 08 February 2013 00:20   |
Am 07.02.2013 21:37, schrieb Jack Lechner:
> Hi!
The general "notification rule" in Net4j and CDO is that low frequency events are fired as IEvents to IListeners and
high frequency "events" are delivered to the application as direct method calls on handler call-backs (to avoid the
creation of events on the heap).Object state changes occur with high frequency, that's why there is
CDOView.addObjectHandler(CDOObjectHandler):
public interface CDOObjectHandler
public void objectStateChanged(CDOView view, CDOObject object, CDOState oldState, CDOState newState);
There's also CDOTransaction.addTransactionHandler(CDOTransactionHandlerBase):
CDOTransactionHandler1.attachingObject(CDOTransaction, CDOObject)
CDOTransactionHandler1.detachingObject(CDOTransaction, CDOObject)
CDOTransactionHandler1.modifyingObject(CDOTransaction, CDOObject, CDOFeatureDelta)
CDOTransactionHandler2.committingTransaction(CDOTransaction, CDOCommitContext)
CDOTransactionHandler2.committedTransaction(CDOTransaction, CDOCommitContext)
CDOTransactionHandler2.rolledBackTransaction(CDOTransaction)
CDOTransactionHandler3.committedTransaction(CDOTransaction, CDOCommitContext, CDOCommitInfo)
Does that help?
Cheers
/Eike
http://www.esc-net.de
FUDForum. Page generated in 0.04411 seconds
