Home » Modeling » Epsilon » Epsilon Development Tools on Eclipse 4.3
Epsilon Development Tools on Eclipse 4.3 [message #1008596] Wed, 13 February 2013 04:03 Go to next message
Hi all,
I try to install Epsilon Development Tools on Eclipse 4.3. I get the following dependeny error even though EMF Compare is installed from the 4.3 update site.
Cannot complete the install because one or more required items could not be found.
Software being installed: Epsilon Development Tools for EMF 1.0.0.201211082326 (org.eclipse.epsilon.emf.dt.feature.feature.group 1.0.0.201211082326)
Missing requirement: Epsilon Development Tools for EMF 1.0.0.201211082326 (org.eclipse.epsilon.emf.dt.feature.feature.group 1.0.0.201211082326) requires 'org.eclipse.emf.compare.ui 0.0.0' but it could not be found
The update site I use is http://download.eclipse.org/epsilon/updates/. Is there an alternative update site available with a built for Eclipse 4.3?
Ralph
Re: Epsilon Development Tools on Eclipse 4.3 [message #1008628 is a reply to message #1008596] Wed, 13 February 2013 06:03 Go to previous messageGo to next message
Hi Ralph,
There have been some backwards-incompatible changes in Kepler regarding EMF Compare (Kepler uses 2.x instead of 1.x), so Epsilon 1.0 will not install properly in there.
I think we addressed these issues in our latest interim build. Could you give it a try? Except for the EUnit assertEqualModels assertion, everything should work.
http://download.eclipse.org/epsilon/interim/
-- Antonio
Re: Epsilon Development Tools on Eclipse 4.3 [message #1008631 is a reply to message #1008596] Wed, 13 February 2013 06:05 Go to previous messageGo to next message
Incidentally, we have some fixes for these assertions as well, but we haven't had time yet to properly integrate the fixes into our build process. We'll probably need to build a Kepler-specific update site sometime soon.
Do you need the assertEqualModels assertions before Kepler is released?
Re: Epsilon Development Tools on Eclipse 4.3 [message #1008640 is a reply to message #1008631] Wed, 13 February 2013 06:42 Go to previous message
I only use EVL. This installs fine with the interims update site you mentioned.
Ralph
Previous Topic:Emfatic/Eugenia
Next Topic:Why model in Epsilon?
Current Time: Sat Jul 26 11:01:18 EDT 2025
Powered by FUDForum. Page generated in 0.05710 seconds
