Re: HowTo sum (accumulate) aggregate values in chart BIRT Eclipse [message #1008694 is a reply to message #1008595] |
Wed, 13 February 2013 10:44   |
Eclipse Guest Messages: 93 Registered: February 2013 Location: Vienna |
Member |
In the 'Select Data' screen of your chart, for Category (X) Series select the DATE field, as you probably already did. To the right of this field, right of 'fx' you can select the X axis grouping. There you can set the aggregation period to one month.
In the Value (Y) Series field, put ID (even DATE would work I think). To the left of the Value (Y) Series field, there is a dropdown menu with a sum icon on it. Expand the dropdown list and choose 'Aggregate Expression: Running Count'.
I hope this will do the trick for you. Cheers, Jakob
Re: HowTo sum (accumulate) aggregate values in chart BIRT Eclipse [message #1009494 is a reply to message #1009297] |
Fri, 15 February 2013 03:28   |
Hi Michael,
Thank you for the info.
I will try to explain step by step what I did and attach the chart I have got.
I have a table with Date, ID (2 columns). I use it in the chart (i.e. Select Data field is "USe Report Item" and I choose the table with the 2 columns).
I create the chart and:
1) In the 'Select Data' screen of your chart, for Category (X) Series select the DATE field
2) right of 'fx' you can select the X axis grouping : at this step I have choosen:
- Data Sorting: Ascending
- Grouping: Enabled
- Type: DateTime
- Unit: Month
- Interval: 1
- Aggregation Expression: Count
3) In the Value (Y) Series field, put ID: In this case I have put row._rownum (number of items in a month)
4) To the left of the Value (Y) Series field, in the dropdowm menu I choose "Count" as you suggested.
The result is attached picture.
AS you can see we have the number of items for each month. (e.g. 04/2011, 1; 06/2011, 2; 07/2011, 3; and so on).
BUT what I would like to achieve is to have a sum of them (accumulated per month) (e.g. for the example above I would like to have a chart showing : 04/2011, 1; 06/2011, 3; 07/2011, 6; and so on).
Could you please help me on achieving this? I think I miss the little final step to get it.
I really appreciate your help.
Alberto
Re: HowTo sum (accumulate) aggregate values in chart BIRT Eclipse [message #1010941 is a reply to message #1010779] |
Mon, 18 February 2013 09:16   |
Member |
Okay, I wasn't aware of that the running count is not available in earlier BIRT versions.
I created a scripted version of the running count by adding a computed column to the dataset. Of course this adds some redundant data to the processing, but that's what comes to my mind and which works... I will attach the report but in case you are not able to view it, here are the steps:
- make sure your data is retrieved ordered by date (add "ORDER BY DATE" to your sql query)
- add a computed column to your dataset, name it "running_count", set type to integer, and expression to 0. click ok to save
- while the dataset is selected, click the script button to open scripting for that dataset
- in "before open", type:
i=0;
- in "onFetch", type:
i++;
row["running_count"] = i;
- in your chart, for Value (Y) Series, select the row["running_count"]
(it will not appear in the data selection, so you have to edit your data bindings or re-select the datasource or recreate the chart with the updated dataset)
- as aggregate function for Value (Y) Series, select MAXIMUM or LAST
Finally I hope that BIRT 2.2.1 supports the aggregate function MAXIMUM or LAST... if not then I don't know anymore :S
FUDForum. Page generated in 0.05302 seconds
