Gemini Blueprint 2.0.0.M01 [message #1008460] |
Tue, 12 February 2013 10:22  |
The first milestone of Gemini Blueprint 2.0 is available for download:
http://www.eclipse.org/gemini/blueprint/download/
with documentation:
http://www.eclipse.org/gemini/blueprint/documentation/reference/2.0.0.M01/html/index.html
Thanks for contributions from:
Andrew Clemons
Matt Bishop
Olaf Otto
Changelog:
The fix to bug 356683 is mildly backwards incompatible and so the version of
Gemini Blueprint is bumped to 2.0.
General:
* Bug 356683 - Construct application contexts defined in extender fragments only
once and share across extender instances
* Bug 393960 - Build using Java 6 instead of Java 5
* Bug 351755 - Gemini-core should export org.osgi.service.blueprint package
* Bug 373661 - SwappingServiceReferenceProxy is not thread safe
* Bug 394116 - Lazy activation by loading of class not contained in bundle depends
on Equinox behavior
* Bug 392396 - Inverted class check logic in org.eclipse.gemini.blueprint.extender.internal.activator.ListListenerAdapter
* Bug 374717 - OsgiServiceFactoryBean throws NullPointerException in destroy() when
no OsgiServiceRegistrationListeners are configured
* Bug 374712 - DynamicCollection toArray(T[] a) throws ClassCastException
* Bug 392500 - TypeFactory.getReifiedType(Type) throws StackOverflowError when fed
recursive types
* Bug 395058 - Test with Knopflerfish 3.5
Glyn
FUDForum. Page generated in 0.05208 seconds
