Home » Eclipse Projects » Remote Application Platform (RAP) » any doc or help for creating native custom widget with rap 2.0?
any doc or help for creating native custom widget with rap 2.0? [message #933803] Fri, 05 October 2012 07:04 Go to next message
hi all,
the Developer's Guide link is dead, http://eclipse.org/rap/developers-guide/devguide.php?topic=advanced/custom-widget.html#native
any samples or doc for creating the native custom widgets without JSWriter with RAP 2.0?
Re: any doc or help for creating native custom widget with rap 2.0? [message #933892 is a reply to message #933803] Fri, 05 October 2012 08:35 Go to previous messageGo to next message
Hi.
For RAP 2.0 there are going to be many changes that break existing
native custom widgets. Since we are still in the middle implementing
these changes, there is currently no point in writing a guide for custom
widget development on RAP 2.0. There will definitely be a guide, but i
can't say when, except that it should be before the 2.0 release.
Greetings,
Tim
Am 05.10.2012 13:04, schrieb Song David:
> hi all,
Tim Buschtöns
Twitter: @EclipseRAP
Re: any doc or help for creating native custom widget with rap 2.0? [message #938923 is a reply to message #933892] Wed, 10 October 2012 05:21 Go to previous messageGo to next message
Thanks to Buschtoens.
Hope to have a simple document or tutorial, I intend to develop my new project on RAP 2.0, and now I do not know how to start with custom widget and old custom widget can not work on RAP 2.0 any more.
Re: any doc or help for creating native custom widget with rap 2.0? [message #1008449 is a reply to message #933892] Tue, 12 February 2013 09:31 Go to previous messageGo to next message
Is there a developer's guide for migrating (developing) custom widgets to the new RAP 2.0 world yet?
The release notes of RAP 2.0 M1, M2, ... RC2 just mention it (but didn't explain) and in RAP wiki (http://wiki.eclipse.org/RAP/Custom_Widgets) the section regarding RAP 2.x is still empty...
Re: any doc or help for creating native custom widget with rap 2.0? [message #1008594 is a reply to message #1008449] Wed, 13 February 2013 03:52 Go to previous messageGo to next message
Custom widget development has become a lot easier with the new Remote
API [1]. Unfortunately, we didn't manage to write a guide yet. However,
there are some examples to learn from. I'd recommend to have a look at
the CKEditor widget [2], which uses the new API and is up to date with
2.0. API documentation is also available: [3] for the Java Remote API
and [4] for JavaScript API.
Let us know how if you notice any problems. Your input will help us
creating a custom widget guide.
Ralf
[1] http://eclipsesource.com/blogs/?p=14197&preview=true
[2] https://github.com/eclipsesource/rap-ckeditor/
[3]
http://download.eclipse.org/rt/rap/doc/2.0/guide/reference/api/org/eclipse/rap/rwt/remote/RemoteObject.html
[4]
http://download.eclipse.org/rt/rap/doc/2.0/guide/reference/jsdoc/symbols/rap.html
Ralf Sternberg
Re: any doc or help for creating native custom widget with rap 2.0? [message #1009068 is a reply to message #1008594] Thu, 14 February 2013 06:21 Go to previous messageGo to next message
Hi Ralf,
thx for your quick response and the links provided.
I just started migrating a non-GUI widget based on the links you provided. Communication between server and client side is working fine (using pure JSON now). Notifications (triggered on client side) are working as well.
Using the LCA approach for implementing custom widgets isn't recommend by the release notes of RAP 2.0. Nonetheless RAP 2.0 still uses LCAs for its widgets. Why? Is using the LCA approach still a way for migrating my custom widgets? Or shall I eliminate all LCA usage?
How do I migrate custom widgets based on qooxdoo? Where do I have to place my code handling things like "rap.registerTypeHandler('myCustomWidget')" and the like? In the qooxdoo-constructor of my widget?
Any suggestions are welcome Smile
Thorsten Lichtenwalter
Software Development
msgGillardon AG, Bretten, Germany
Re: any doc or help for creating native custom widget with rap 2.0? [message #1009162 is a reply to message #1009068] Thu, 14 February 2013 10:13 Go to previous message
Hi Thorsten,
> working as well.
That's good to hear :)
> its widgets. Why?
Because it's a whole lot of work to change that. Anyway, the widget LCAs
will be changed to use the Remote API as well. We're looking forward to
replace the concept of lifecycle phases in favor of the remote API in
some future version.
LCAs are still supported but discouraged for new widgets. At some point
in time, we'll have to discontinue support for LCAs.
You probably know that RAP maintains a modified subset of qooxdoo. The
classes have moved to the rwt namespace. However, you can use these
classes at your own risk.
The typehandler has to be registered only once, directly in the code
that defines the widget. In the factory function, you'd create an
instance of your widget.
Regards, Ralf
Ralf Sternberg
Previous Topic:[ANN] RAP 2.0 M2 is available
Next Topic:RAP/RWT JUnit testing
Current Time: Sat Jul 26 02:36:15 EDT 2025
Powered by FUDForum. Page generated in 0.05532 seconds
