Home » Modeling » Papyrus » How to use MARTE GQAM
How to use MARTE GQAM [message #1008399] Tue, 12 February 2013 05:27 Go to next message
I am trying to stereotype some elements of my model with the MARTE GQAM stereotypes but I am having troubles in assigning values to some of their properties. For instance I have stereotyped a message between two lifelines as <<gaAcqStep>>. I would like to assign a value to its hostDemand property which shall be a NFP_Duration instance.
I can't see how to use the Papyrus editor to create a NFP_Duration instance and assign it to the hostDemand property.
[Updated on: Tue, 12 February 2013 05:27] by Moderator
Re: How to use MARTE GQAM [message #1009027 is a reply to message #1008399] Thu, 14 February 2013 05:04 Go to previous messageGo to next message
here is a StackOverflow question I posted about this topic http://stackoverflow.com/questions/14841748/using-marte-gqam-stereotypes-in-papyrus-uml-models
Re: How to use MARTE GQAM [message #1009553 is a reply to message #1009027] Fri, 15 February 2013 05:00 Go to previous messageGo to next message
Any help would be very appreciated Smile
Thank you very much
Re: How to use MARTE GQAM [message #1014713 is a reply to message #1009553] Tue, 26 February 2013 05:32 Go to previous messageGo to next message
Is there anyone using MARTE who can answer this?
I am sorry to bother but I am currently stuck on it
Thank you!
Re: How to use MARTE GQAM [message #1015307 is a reply to message #1014713] Thu, 28 February 2013 02:45 Go to previous messageGo to next message
Hi Andrea,
i am a beginner in UML and i have a lot of questions and also don't know about MARTE but i made a comprehensive search for you and found this forum
http://www.modelio.org/forum/9-extensions.html
you can post your question about MARTE
I do know it is not for Papyrus but I really do my best to help you
Re: How to use MARTE GQAM [message #1295412 is a reply to message #1014713] Mon, 14 April 2014 04:45 Go to previous message
I'm facing with exactly the same problem. Did you then discover how to create an instance of NFP_Duration (or NFP_Frequency, according to this other your post: https://www.eclipse.org/forums/index.php/m/1007869/?srch=marte+nfp#msg_1007869) and to assign it to a property of a MARTE stereotype?
Matteo
Previous Topic:Control Flow Default values for guard and weight
Next Topic:How to assign NFP values to properties of MARTE stereotypes in (Papyrus) UML models
Current Time: Sat Jul 26 19:11:44 EDT 2025
Powered by FUDForum. Page generated in 0.02932 seconds
