Home » Eclipse Projects » Rich Client Platform (RCP) » Reusing plugins folder for multiple RCP applications
Reusing plugins folder for multiple RCP applications [message #1000287] Mon, 14 January 2013 07:53 Go to next message
Hallo
sorry to repost, but there has not been any reaction on the Equinox forum, so I thought I would try it here:
We have multiple RCP applications running on windows. Each of these applications uses about 90% of the same plugins. I would like all plugins to be in same folder for easier provisioning and updating.
I have tried 2 different scenarios, but I am having trouble to set this up. Any help is very welcome!
Please have a look at my post on the equniox forum for details:
http://www.eclipse.org/forums/index.php/mv/msg/446601/997574/#msg_997574
Thanks for the help!
Greetings
Christoph
Re: Reusing plugins folder for multiple RCP applications [message #1002342 is a reply to message #1000287] Fri, 18 January 2013 07:32 Go to previous messageGo to next message
You can use a "shared dropins directory" to avoid the copy altogether.
Modify tour eclipse.ini for both installation:
-Dorg.eclipse.equinox.p2.reconciler.dropins.directory=/<myPath>/mySharedDropins
Re: Reusing plugins folder for multiple RCP applications [message #1002351 is a reply to message #1002342] Fri, 18 January 2013 07:46 Go to previous messageGo to next message
Hi Sumit
thanks for your input! Unfortunately, this alone does not do the trick. The executable still starts with an error: "The executable launcher was unable to locate its companion shared library".
Greetings
Christoph
Re: Reusing plugins folder for multiple RCP applications [message #1008348 is a reply to message #1002351] Tue, 12 February 2013 01:01 Go to previous message
Take a look for following links there is step by step procedure.
the-easy-way-to-reinstall-eclipse-and-share-plugins-across-multiple-installations
Previous Topic:Visual Datasets
Next Topic:IPartListener partClosed & partActivated notification
Current Time: Fri Jul 25 17:28:41 EDT 2025
Powered by FUDForum. Page generated in 0.04712 seconds
