| I need XML validation support [message #996006] |
Mon, 31 December 2012 14:47  |
I like to use Eclipse to edit FB2 files (fictionbook.org).
I can not use links in the message, so:
{web} = h t t p : / / w w w
without spaces.
The file header .fb2 is:
<?xml version="1.0" encoding="utf-8">
<FictionBook xmlns="{web}.gribuser.ru/xml/fictionbook/2.0" xmlns:l="{web}.w3.org/1999/xlink">
</ FictionBook>
The XML Schema files are online. I can not modify them. Please review them (only header) to understand the problem:
{web}.gribuser.ru/xml/fictionbook/2.0/xsd/FictionBook2.xsd
{web}.gribuser.ru/xml/fictionbook/2.0/xsd/FictionBookGenres.xsd
{web}.gribuser.ru/xml/fictionbook/2.0/xsd/FictionBookLang.xsd
{web}.gribuser.ru/xml/fictionbook/2.0/xsd/FictionBookLinks.xsd
I added two "Catalog Entry" in "XML Catalog" with the new namespaces:
Location: {web}.gribuser.ru/xml/fictionbook/2.0/xsd/FictionBook2.xsd
Key Type: Namespace name
key: {web}.gribuser.ru/xml/fictionbook/2.0
Location: {web}.gribuser.ru/xml/fictionbook/2.0/xsd/FictionBookGenres.xsd
key: {web}.gribuser.ru/xml/fictionbook/2.0/genres
I have no knowledge of XSD, but I think the problem is that the file {web}.gribuser.ru/xml/fictionbook/2.0/xsd/FictionBookLang.xsd uses an obsolete namespace (W3C):
{web}.w3.org/XML/1998/namespace
{web}.gribuser.ru/xml/fictionbook/2.0/xsd/FictionBookLang.xsd:
<!-- edited with XML Spy v4.4 U ({web}.xmlspy.com) by Dmitry Gribov (DDS) -->
<xs:schema targetNamespace="{web}.w3.org/XML/1998/namespace" xmlns:xs="{web}.w3.org/2001/XMLSchema" xmlns="{web}.w3.org/XML/1998/namespace" elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:attribute name="lang" type="xs:language">
<xs:annotation>
<xs:documentation>Element content's languige</xs:documentation>
</xs:annotation>
</xs:attribute>
</xs:schema>
Is it possible to validate FB2 files with XML Catalog or other Eclipse tool/plugin?
thanks
| Re: I need XML validation support [message #1008271 is a reply to message #997135] |
Mon, 11 February 2013 05:39  |
sorry for the late reply.
Could you post the web location of the fictionbook xsds? I tried to
browse http://gribuser.ru/xml/fictionbook/2.0 - but this seems to result
in a 404 error, and I cannot read the page ;-).
I found the files (2.2 version) also here:
http://yaboobooker.googlecode.com/svn-history/r3/trunk/schemas/2.2
Using Eclipse, I could create this xml file. Take a look at the schema
location "xsi:schemaLocation="http://www.gribuser.ru/xml/fictionbook/2.0
http://yaboobooker.googlecode.com/svn-history/r3/trunk/schemas/2.2/FictionBook.xsd".
<p:FictionBook xmlns:p="http://www.gribuser.ru/xml/fictionbook/2.0"
xmlns:p1="http://www.w3.org/1999/xlink"
xmlns:p2="http://www.gribuser.ru/xml/fictionbook/2.0/genres"
xmlns:xml="http://www.w3.org/XML/1998/namespace"
<p:description>
<p:title-info>
<p:genre>sf_history</p:genre>
<p:author>
<p:first-name>Test</p:first-name>
<p:middle-name>middle</p:middle-name>
<p:last-name>last</p:last-name>
</p:author>
<p:book-title>p:book-title</p:book-title>
<p:lang>p:lang</p:lang>
</p:title-info>
<p:document-info>
<p:author>
</p:author>
<p:date>p:date</p:date>
<p:id>token</p:id>
<p:version>0.0</p:version>
</p:document-info>
</p:description>
<p:body>
<p:section />
</p:body>
</p:FictionBook>
You could also add the xsd files to your xml catalog, but I did not
manage to handle this ;-). It seems that the somehow overwrite some xml
standard XSDs, this is somehow "strange"...
Best regards
Wolfgang
Am 03.01.2013 22:56, schrieb Felipe Lotas:
> The online XSDs contents are
> FictionBook2.xsd
> <xs:schema targetNamespace="{web}.gribuser.ru/xml/fictionbook/2.0"
> xmlns:xlink="{web}.w3.org/1999/xlink"
> xmlns:genre="{web}.gribuser.ru/xml/fictionbook/2.0/genres"
> <xs:import namespace="{web}.w3.org/1999/xlink"
> schemaLocation="FictionBookLinks.xsd"/>
> <xs:import namespace="{web}.gribuser.ru/xml/fictionbook/2.0/genres"
> schemaLocation="FictionBookGenres.xsd"/>
> <xs:import namespace="{web}.w3.org/XML/1998/namespace"
> schemaLocation="FictionBookLang.xsd"/>
> <xs:element name="FictionBook">
> ... [large file] ...
> </xs:element>
> </xs:schema>
> <xs:schema
> targetNamespace="{web}.gribuser.ru/xml/fictionbook/2.0/genres"
> xmlns="{web}.gribuser.ru/xml/fictionbook/2.0/genres"
> xmlns:xs="{web}.w3.org/2001/XMLSchema" elementFormDefault="qualified"
> <xs:simpleType name="genreType">
> </xs:simpleType>
> </xs:schema>
> <xs:schema targetNamespace="{web}.w3.org/1999/xlink"
> xmlns:xs="{web}.w3.org/2001/XMLSchema" xmlns="{web}.w3.org/1999/xlink"
> <xs:attribute name="type" type="xs:string" fixed="simple">
> <xs:annotation>
> <xs:documentation>link type</xs:documentation>
> </xs:annotation>
> </xs:attribute>
> <xs:attribute name="href" type="xs:string">
> <xs:annotation>
> <xs:documentation>link target</xs:documentation>
> </xs:annotation>
> </xs:attribute>
> </xs:schema>
> FictionBookLang.xsd
> <xs:annotation>
> </xs:annotation>
> </xs:attribute>
> </xs:schema>
> I have modified my local copy of the files used in Eclipse validation.
> The modified FictionBook2.xsd is
> schemaLocation="{web}.w3.org/2001/xml.xsd"/>
> </xs:element>
> </xs:schema>
> Now FictionBookLang.xsd is not used. I override the import of
> FictionBookLang.xsd in FictionBook2.xsd with
> I have no knowledge about XML schemas. I'd like to use Eclipse to edit
> FB2 files and validate them, but seems that Eclipse XML Catalog don't
> like FictionBookLang.xsd's contents.
> Is my solution/triky correct in terms of XML schemas?
> Is a correct FB2 validation? Does 2001/xml.xsd define the same lang
> atribute that 1998/namespace?
> Thanks
FUDForum. Page generated in 0.25317 seconds
