Home » Eclipse Projects » EclipseLink » Version 2.4.2 M5 - The query contains a malformed ending(@NamedQuery, IN Clause, OK in 2.3.3, Fails withHermes Parser )
Version 2.4.2 M5 - The query contains a malformed ending [message #1007878] |
Thu, 07 February 2013 16:56  |
Is there any syntax change in 2.4.2? Does anyone see where the trouble might be in the named query below? This query and all related code works in EclipseLink 2.3.3. I get the same result on Oracle 11gR2 or 10gR2, with Java 6u39 and Eclipse indigo.
The trouble is likely in
"( TRIM(FROM u.userStatus) IN :userStatusList )"
because there is an identical named query just before this one, but without this clause.
, @NamedQuery( name = "LastFirstID.findLikeUsernameByStatus"
, query = "SELECT l FROM LastFirstID l "
+" WHERE l.IDNumber IN (SELECT DISTINCT u.IDNumber "
+" FROM Username u "
+" WHERE ( ( LOWER(TRIM(FROM u.loginID )) LIKE :usernamePattern ) "
+" AND ( TRIM(FROM u.userStatus) IN :userStatusList ) ) )"
+" ORDER BY FUNC('TRANSLATE_CHAR', LOWER( FUNC('NVL', l.lastName, ' ') )), "
+" FUNC('TRANSLATE_CHAR', LOWER( FUNC('NVL', l.firstName,' ') )) " /* Ignore diacritical marks and case when ordering the names list */
Quote:[java] INFO: EclipseLink, version: Eclipse Persistence Services - 2.4.2.v20130207-ca8d1b6
[java] Feb 7, 2013 4:19:59 PM org.eclipse.persistence.session.file:/C:/Documents and Settings/mrainv/My Documents/Eclipse Projects/icsworkspace_v1_00_EL242M5/StarFinder/dist/StarFinder_V1_00.jar_DMAIN.MCGILL.CA_user=dev_admin.connection
[java] INFO: file:/C:/Documents and Settings/mrainv/My Documents/Eclipse Projects/icsworkspace_v1_00_EL242M5/StarFinder/dist/StarFinder_V1_00.jar_DMAIN.MCGILL.CA_user=dev_admin logout successful
[java] Feb 7, 2013 4:19:59 PM org.eclipse.persistence.session.file:/C:/Documents and Settings/mrainv/My Documents/Eclipse Projects/icsworkspace_v1_00_EL242M5/StarFinder/dist/StarFinder_V1_00.jar_DMAIN.MCGILL.CA_user=dev_admin.ejb
[java] SEVERE:
[java] Local Exception Stack:
[java] Exception [EclipseLink-0] (Eclipse Persistence Services - 2.4.2.v20130207-ca8d1b6): org.eclipse.persistence.exceptions.JPQLException
[java] Exception Description: Syntax error parsing [SELECT l FROM LastFirstID l WHERE l.IDNumber IN (SELECT DISTINCT u.IDNumber FROM Username u WHERE ( ( LOWER(TRIM(FROM u.loginID )) LIKE :usernamePattern ) AND ( TRIM(FROM u.userStatus) IN :userStatusList ) ) ) ORDER BY FUNC('TRANSLATE_CHAR', LOWER( FUNC('NVL', l.lastName, ' ') )), FUNC('TRANSLATE_CHAR', LOWER( FUNC('NVL', l.firstName,' ') )) ].
[java] [201, 348] The query contains a malformed ending.
[java] at org.eclipse.persistence.internal.jpa.jpql.HermesParser.buildException(HermesParser.java:150)
[java] at org.eclipse.persistence.internal.jpa.jpql.HermesParser.validate(HermesParser.java:325)
[java] at org.eclipse.persistence.internal.jpa.jpql.HermesParser.populateQueryImp(HermesParser.java:270)
[java] at org.eclipse.persistence.internal.jpa.jpql.HermesParser.buildQuery(HermesParser.java:157)
[java] at org.eclipse.persistence.internal.jpa.EJBQueryImpl.buildEJBQLDatabaseQuery(EJBQueryImpl.java:138)
[java] at org.eclipse.persistence.internal.jpa.JPAQuery.processJPQLQuery(JPAQuery.java:108)
[java] at org.eclipse.persistence.internal.jpa.JPAQuery.prepare(JPAQuery.java:92)
[java] at org.eclipse.persistence.queries.DatabaseQuery.checkPrepare(DatabaseQuery.java:614)
[java] at org.eclipse.persistence.queries.DatabaseQuery.checkPrepare(DatabaseQuery.java:575)
[java] at org.eclipse.persistence.internal.sessions.AbstractSession.processJPAQueries(AbstractSession.java:2244)
[java] at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:540)
[java] at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:777)
[java] at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:722)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:215)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:551)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:186)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:278)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:304)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:282)
[java] at ca.mcgill.ncs.starfinder.StarFinder.connectDatabase(StarFinder.java:4308)
[java] at ca.mcgill.ncs.starfinder.StarFinder.<clinit>(StarFinder.java:339)
[java] Feb 7, 2013 4:20:10 PM ca.mcgill.ncs.starfinder.StarFinder logNote
[java] SEVERE: Exiting, could not connect; Java message was: Exception [EclipseLink-28019] (Eclipse Persistence Services - 2.4.2.v20130207-ca8d1b6): org.eclipse.persistence.exceptions.EntityManagerSetupException
[java] Exception Description: Deployment of PersistenceUnit [DMAIN.MCGILL.CA] failed. Close all factories for this PersistenceUnit.
[java] Internal Exception: Exception [EclipseLink-0] (Eclipse Persistence Services - 2.4.2.v20130207-ca8d1b6): org.eclipse.persistence.exceptions.JPQLException
Re: Version 2.4.2 M5 - The query contains a malformed ending [message #1008231 is a reply to message #1007878] |
Mon, 11 February 2013 11:16  |
Try using the latest 2.5 nightly builds, and if the problem still exists please file a bug. As a workaround, you can use the ANTLR parser which was used by default in prior releases by specifying the "eclipselink.jpql.parser" persistence property with a value of "org.eclipse.persistence.queries.ANTLRQueryBuilder".
Best Regards,
Chris
Current Time: Fri Jul 25 21:29:40 EDT 2025
Powered by FUDForum. Page generated in 0.04136 seconds
