Home » Modeling » TMF (Xtext) » Unable to launch mwe2 workflow
icon4.gif  Unable to launch mwe2 workflow [message #1008202] Mon, 11 February 2013 06:52 Go to next message
I have installed XText 2.3.1 via the Updatesite, now i wanted to launch my DSL's mwe2-File. Unforunatly i get this error message: "Please put bundle 'org.eclipse.emf.mwe2.launch' on your project's classpath".
What else must be installed from the updatesite? Why is this bundle not included in the normal XText feature, if it is required?
Re: Unable to launch mwe2 workflow [message #1008205 is a reply to message #1008202] Mon, 11 February 2013 08:06 Go to previous messageGo to next message
Hi Christian,
what do you mean with "the normal XText feature"?
Re: Unable to launch mwe2 workflow [message #1008209 is a reply to message #1008205] Mon, 11 February 2013 08:26 Go to previous messageGo to next message
Hi Dennis,
Dennis Huebner wrote on Mon, 11 February 2013 08:06
i mean the red boxed feature i've selected in the new software dialog. If the bundle "org.eclipse.emf.mwe2.launch" is requird by XText to launch mwe2 it should be included!
index.php/fa/13368/0/
  • Attachment: xtext.png
    (Size: 47.15KB, Downloaded 5731 times)
[Updated on: Mon, 11 February 2013 08:29] by Moderator
Re: Unable to launch mwe2 workflow [message #1008210 is a reply to message #1008205] Mon, 11 February 2013 08:27 Go to previous messageGo to next message
duplicate/removed
[Updated on: Mon, 11 February 2013 08:30] by Moderator
Re: Unable to launch mwe2 workflow [message #1008254 is a reply to message #1008210] Mon, 11 February 2013 13:35 Go to previous messageGo to next message
the error message says you have to add a corresponding dependency to the manifest of the project containing the .mwe2 file
Re: Unable to launch mwe2 workflow [message #1008375 is a reply to message #1008209] Tue, 12 February 2013 03:34 Go to previous messageGo to next message
Also check your active target platform. Use "Target Platform State" view.
index.php/fa/13375/0/
Re: Unable to launch mwe2 workflow [message #1008387 is a reply to message #1008375] Tue, 12 February 2013 04:37 Go to previous messageGo to next message
Thanks for your help!
I added the following features to my target platform:
- org.eclipse.emf.common
- org.eclipse.emf.ecore
- org.eclipse.emf.mwe.core
- org.eclipse.emf.mwe2.language.sdk
- org.eclipse.emf.mwe2.runtime.sdk
The bundle org.eclipse.emf.mwe2.launch and it's dependencys is now part of my target platform and can be resolved. No errors were reported in the "Target Platform State"-View.
I also added the org.eclipse.emf.mwe2.launch to plugin-dependencies of the MANIFEST.MF. (Isn't it referenced indirectly by org.eclipse.xtext either?)
Now i get this, when i try to launch the GenerateMyDsl.mwe2 :
Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/log4j/Logger
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.<clinit>(Mwe2Launcher.java:31)
Caused by: java.lang.ClassNotFoundException: org.apache.log4j.Logger
	at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
	at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
	at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:423)
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
	... 1 more
Why do i need the launch - bundle for my plugin, I only want the launch the code-generation from within eclipse, not at runtime? Did I misunderstood something?
Re: Unable to launch mwe2 workflow [message #1008397 is a reply to message #1008387] Tue, 12 February 2013 05:24 Go to previous messageGo to next message
Maybe it is related to my problem: The GenerateMyDsl.mwe2 File contains +60 errors. Here are the first 3...
- "Couldn't resolve reference to JvmType 'Generator'."
- "Couldn't resolve reference to JvmIdentifiableElement 'pathRtProject'."
- "Couldn't resolve reference to JvmIdentifiableElement 'pathUiProject'."
this is the corresponding part of the code:
  component = Generator {
        pathRtProject = runtimeProject
        pathUiProject = "${runtimeProject}.ui"
Re: Unable to launch mwe2 workflow [message #1027095 is a reply to message #1008397] Tue, 26 March 2013 10:50 Go to previous messageGo to next message
The Problem still remains, i have found different ways that didn't work. Dear XText developers can u try the following and tell us how you solve it:
1. Start Eclipse with a new/empty Workspace
2. Create a new XText-Projet using the New-Wizard
3. Create a new empty Target-Platform
4. Add the Features that are needed to the Target-Platform so the XText-Project compiles and run
-> Which Features are needed to be added?
Re: Unable to launch mwe2 workflow [message #1027317 is a reply to message #1027095] Tue, 26 March 2013 17:08 Go to previous messageGo to next message
Concerning the target platform, these two features should be enough
org.eclipse.platform
org.eclipse.xtext.sdk
(provided also the included software is selected).
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Re: Unable to launch mwe2 workflow [message #1027640 is a reply to message #1027317] Wed, 27 March 2013 04:03 Go to previous messageGo to next message
Thanks for your help. I figured out that org.eclipse.platform and org.eclipse.xtext.sdk + its dependencies is not enough. I also added all the mwe stuff and plugins that are not part of any feature like hamcrest and junit. In the end i got 42 features selected in my target platform i guess this are more than 200-Plugins. Here are my results of the sample project:
  • org.xtext.example.mydsl contains no errors and compiles, but when i try to run the GenerateMyDsl.mwe2 i get: java.lang.ClassNotFoundException: org.eclipse.xtend.expression.ExecutionContext
  • org.xtext.example.mydsl.sdk contains no errors and compiles
  • org.xtext.example.mydsl.tests does not resolve the junit packages although it is included as implicit dependency in the target platform
  • org.xtext.example.mydsl.ui does not resolve org.eclipse.ui.ide;bundle-version="3.5.0" because i am running on e4.2, but that okay for now
I think there is no other solution for my current project to chase the complie error i have to leave them. Because we don't need the generated ui plugin of our dsl we can life with that. Whenever we have to change our language we switch our project target platform to ${eclipse-home} were every thing is fine for xtext (but not the rest of our project) and generate the code again. This is not the best solution but i guess it the only workaround on the horiziont.
[Updated on: Wed, 27 March 2013 04:04] by Moderator
Re: Unable to launch mwe2 workflow [message #1027807 is a reply to message #1027640] Wed, 27 March 2013 08:39 Go to previous messageGo to next message
I created a brand new Xtext project (as you did) and created this
juno.target file
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.8"?>
<target name="juno" sequenceNumber="0">
<locations>
<location includeAllPlatforms="false" includeConfigurePhase="true"
includeMode="planner" includeSource="true" type="InstallableUnit">
<unit id="org.eclipse.platform.feature.group"
version="4.2.1.v20130118-173121-9MF7GHYdG0B5kx4E_SkfZV-1mNjVATf67ZAb7"/>
<unit id="org.eclipse.xtext.sdk.feature.group"
version="2.3.1.v201208210947"/>
<repository location="http://download.eclipse.org/releases/juno"/>
</location>
</locations>
</target>
if I set this as the target platform everything works perfectly, and I
can run the mwe2 workflow without any error...
(hamcrest and junit stuff are dragged in automatically since they are
dependencies)
you were talking about a standard .target definition file, weren't you?
cheers
Lorenzo
> project:
Re: Unable to launch mwe2 workflow [message #1783387 is a reply to message #1008202] Mon, 12 March 2018 10:41 Go to previous message
I had this problem on linux.
I installed the Plug-in Developers Environment (PDE).
Help → Install New Software... → Choose The Eclipse Project Updates in field Work With → Filter for RCP Plug-In
Previous Topic:What do you think about link cast operator to a "toX" function?
Next Topic:Unable to run workflow in RCP
Current Time: Sat Jul 26 07:52:27 EDT 2025
Powered by FUDForum. Page generated in 0.27921 seconds
