Home » Modeling » Epsilon » Emfatic/Eugenia(Problem Generating Emfatic file or .emf file from ecore)
Emfatic/Eugenia [message #1008028] Fri, 08 February 2013 10:18 Go to next message
Dear All.
I tried to generate emfatic file from ecore model by right clicking and selecting generate emfatic source from .ecore model but it keep giving me this message
"The chosen opeartion is not currently available"
Secondly I tried to start up a new emfatic file via File->New->other->select a
wizard, and I got this error message below:
"The selected wizard could not be started.
Plug-in org.eclipse.emf.emfatic.ui was unable to load class
org.eclipse.emf.emfatic.ui.wizards.EmfaticNewWizard.
org/eclipse/emf/emfatic/ui/wizards/EmfaticNewWizard : Unsupported
major.minor version 51.0"
I am new to Emfatic and Eugenia. I have downloaded and installed the eclipse epsilon, and also installed the updates using the following link
http://eclipse.org/epsilon/download/.
I am a Mac OS user, and I think the JRE in my eclipse is 1.6.0.
Please can anyone help.
Joshua
Re: Emfatic/Eugenia [message #1008035 is a reply to message #1008028] Fri, 08 February 2013 10:42 Go to previous messageGo to next message
Hi Joshua,
This looks like a Java version issue. Could you please update to Java 1.7 from [1] and let me know if doing so solves this problem?
Dimitris
[1] http://java.com/en/download/manual.jsp
Re: Emfatic/Eugenia [message #1008071 is a reply to message #1008035] Fri, 08 February 2013 12:50 Go to previous messageGo to next message
Thanks Dimitris,
I tried to install Java 1.7 using this link, but it said that the link is for higher version of mac, i.e Mac osx Lion, the version of mac I am using is 10.6.8. Please can you send me the Link to update to java 1.7 in mac osx 10.6.8.
Joshua
Re: Emfatic/Eugenia [message #1008125 is a reply to message #1008071] Sun, 10 February 2013 04:11 Go to previous messageGo to next message
Hi Joshua,
It appears that 1.7 is not available for Snow Leopard so I've reverted the Emfatic update site to use 1.6 and added a note to http://eclipse.org/epsilon/download/. Could you please update Emfatic from the following update site and let me know if it works?
http://download.eclipse.org/emfatic/update/
Dimitris
Re: Emfatic/Eugenia [message #1008181 is a reply to message #1008125] Mon, 11 February 2013 05:04 Go to previous message
Thank you very much Dimitris, its now working and I am up and running.
Joshua
Previous Topic:How to generate preserved regions from EGL @template operation
Next Topic:Epsilon Development Tools on Eclipse 4.3
Current Time: Fri Jul 25 21:35:21 EDT 2025
Powered by FUDForum. Page generated in 0.26966 seconds
