Home » Eclipse Projects » Eclipse Scout » Export fails on Mac OS X Java 7
Export fails on Mac OS X Java 7 [message #1008157] Mon, 11 February 2013 02:15 Go to next message
Hello everyone
I'd like to ask if anyone of you has encountered the following problem or knows a solution:
I just set up a brand-new installation of Mac OS X 10.7.5 with Oracle Java JDK 7 (1.7.13).
With Scout Juno SR1, I used the project wizard to create a sample project with 1 form and tried to export it.
However, the export wizard fails with the following error when exporting the swing client product:
~/Development/scout-workspace/.metadata/.plugins/org.eclipse.pde.core/temp/org.eclipse.pde.container.feature/compile.org.eclipse.pde.container.feature.xml:4: The following error occurred while executing this line:
~/Development/scout-workspace/ch.defiant.scouttutorial.shared/build.xml:31: /Library/Java/JavaVirtualMachines/jdk1.7.0_13.jdk/Contents/Home/Classes does not exist.
Indeed, the folder "Class" folder in "/Library/Java/JavaVirtualMachines/jdk1.7.0_13.jdk/Contents/Home/Classes" does not exist.
Is this an installation problem, configuration problem (environment) or a bug?
Kind regards,
Patrick
java version "1.7.0_13"
Java(TM) SE Runtime Environment (build 1.7.0_13-b20)
Java HotSpot(TM) 64-Bit Server VM (build 23.7-b01, mixed mode)
Version: Juno Service Release 1
Build id: 20120920-0800
Scout 3.8.1.201209171521
Re: Export fails on Mac OS X Java 7 [message #1008165 is a reply to message #1008157] Mon, 11 February 2013 03:42 Go to previous messageGo to next message
Hi Patrick
This is probably due to the bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=378445
Can you try again with SR2 RC3?
http://download.eclipse.org/scout/releases/3.8/3.8.2
Judith
Re: Export fails on Mac OS X Java 7 [message #1008229 is a reply to message #1008165] Mon, 11 February 2013 10:56 Go to previous messageGo to next message
Hello Judith
Has that download been moved?
The link doesn't seem to be working for me (404) and it is not linked anywhere else on the download site...
TIA,
Patrick
Re: Export fails on Mac OS X Java 7 [message #1008233 is a reply to message #1008229] Mon, 11 February 2013 11:18 Go to previous messageGo to next message
Hi Patrick.
The page is not a real 404:
This is an Eclipse Update site/p2 repository; you must access it from Eclipse (see how).
icon14.gif  Re: Export fails on Mac OS X Java 7 [message #1008297 is a reply to message #1008233] Mon, 11 February 2013 14:47 Go to previous message
Ah thank you Jérémie and Judith.
Now it worked.
For everyone else with this problem:
I had to download the developer build for Juno SR2 (Eclipse itself needed the update, not only the scout plugins), because it is not itself a Scout-Bug.
Patrick
Previous Topic:RadioButtonGroup not disabling its children
Next Topic:child page do not decorate untll it's been clicked in an outline based application
Current Time: Wed Jul 23 07:35:16 EDT 2025
Powered by FUDForum. Page generated in 0.29023 seconds
