Home » Modeling » ATL » model merging
model merging [message #1007653] Wed, 06 February 2013 16:45 Go to next message
Hi to everyone,
I'm trying to merge two UML models in ATL:
Model1:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:VaProfile="http:///schemas/VaProfile/_NoMJ4Gx_EeK4SYm4A9jwEQ/86" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" xsi:schemaLocation="http:///schemas/VaProfile/_NoMJ4Gx_EeK4SYm4A9jwEQ/86 ../VAMProfileCopy/psprofile.profile.uml#_Noz08Gx_EeK4SYm4A9jwEQ">
  <uml:Model xmi:id="_riNzQGSgEeKEuaD-A95eUA" name="localeUML2">
    <packageImport xmi:id="_riNzQWSgEeKEuaD-A95eUA">
      <importedPackage xmi:type="uml:Model" href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
    </packageImport>
    <packagedElement xmi:type="uml:Class" xmi:id="_Heyy4GShEeKEuaD-A95eUA" name="Room">
      <nestedClassifier xmi:type="uml:Class" xmi:id="_Vf7LUGShEeKEuaD-A95eUA" name="Pillar1"/>
      <nestedClassifier xmi:type="uml:Class" xmi:id="_V7Y_UGShEeKEuaD-A95eUA" name="Pillar2"/>
      <nestedClassifier xmi:type="uml:Class" xmi:id="_WYjccGShEeKEuaD-A95eUA" name="Server">
        <nestedClassifier xmi:type="uml:Class" xmi:id="_LVSGcGk6EeKqn4ij9uqv2g" name="HardDisk"/>
      </nestedClassifier>
    </packagedElement>
    <profileApplication xmi:id="_riNzQmSgEeKEuaD-A95eUA">
      <eAnnotations xmi:id="_riNzQ2SgEeKEuaD-A95eUA" source="http://www.eclipse.org/uml2/2.0.0/UML">
        <references xmi:type="ecore:EPackage" href="http://www.eclipse.org/uml2/schemas/Standard/1#/"/>
      </eAnnotations>
      <appliedProfile href="pathmap://UML_PROFILES/Standard.profile.uml#_0"/>
    </profileApplication>
    <profileApplication xmi:id="_zAZcEGSgEeKEuaD-A95eUA">
      <eAnnotations xmi:id="_zAdtgGSgEeKEuaD-A95eUA" source="http://www.eclipse.org/uml2/2.0.0/UML">
        <references xmi:type="ecore:EPackage" href="../VAMProfileCopy/psprofile.profile.uml#_Noz08Gx_EeK4SYm4A9jwEQ"/>
      </eAnnotations>
      <appliedProfile href="../VAMProfileCopy/psprofile.profile.uml#_g3R-UCp7EeK9bM-qugGxvg"/>
  </uml:Model>
  <VaProfile:Object xmi:id="_ZeXr8GSjEeKEuaD-A95eUA" base_Classifier="_Vf7LUGShEeKEuaD-A95eUA" location="_fZfmkGSjEeKEuaD-A95eUA"/>
  <VaProfile:Object xmi:id="_beLnkGSjEeKEuaD-A95eUA" base_Classifier="_V7Y_UGShEeKEuaD-A95eUA" location="_fZfmkGSjEeKEuaD-A95eUA"/>
  <VaProfile:Object xmi:id="_c5Ll8GSjEeKEuaD-A95eUA" base_Classifier="_WYjccGShEeKEuaD-A95eUA" location="_fZfmkGSjEeKEuaD-A95eUA"/>
  <VaProfile:Site xmi:id="_fZfmkGSjEeKEuaD-A95eUA" base_Classifier="_Heyy4GShEeKEuaD-A95eUA"/>
  <VaProfile:Object xmi:id="_TkduYGk6EeKqn4ij9uqv2g" base_Classifier="_LVSGcGk6EeKqn4ij9uqv2g" location="_fZfmkGSjEeKEuaD-A95eUA"/>
</xmi:XMI>
and Model2:
  <uml:Model xmi:id="_IkOT4HBoEeKcgp_s5TSrqg" name="protections">
    <packagedElement xmi:type="uml:Class" xmi:id="_IkOT4XBoEeKcgp_s5TSrqg" name="_OB0ToGSkEeKEuaD-A95eUA"/>
    <packagedElement xmi:type="uml:Class" xmi:id="_IkOT5HBoEeKcgp_s5TSrqg" name="_PQeYsGpCEeK6StkFpCf91Q"/>
    <profileApplication xmi:id="_IkOT5XBoEeKcgp_s5TSrqg">
      <eAnnotations xmi:id="_IkOT5nBoEeKcgp_s5TSrqg" source="http://www.eclipse.org/uml2/2.0.0/UML">
      </eAnnotations>
  </uml:Model>
  <VaProfile:Sensor xmi:id="_IkOT53BoEeKcgp_s5TSrqg" base_Classifier="_IkOT4XBoEeKcgp_s5TSrqg" cost="100.0"/>
  <VaProfile:Sensor xmi:id="_IkOT6HBoEeKcgp_s5TSrqg" base_Classifier="_IkOT5HBoEeKcgp_s5TSrqg" cost="200.0"/>
</xmi:XMI>
More precisely I'm trying to pickup all classes and stereotypes from model2 and put them into model1.
At first I tried to figure it out with a refinement approach but I faced the problem to use the resolveTemp in an action block, but action blocks are forbidden in refinement mode.
Then I tryied a copy approach, generating all the elements needed and assigning them the values properly, but I faced a problem when managing nested elements.
I read this post http://www.eclipse.org/forums/index.php/m/989963/
where I noticed this sentence:
"In ATL, you can set references between elements from different models as long as these references are not containment references."
Than I'm a bit stuck and I don't know if my problam as a solution or I'm not able to find out one.
I don't know which approach follow and how to do.
I hope you can help me,
Claudio
Re: model merging [message #1007917 is a reply to message #1007653] Fri, 08 February 2013 03:10 Go to previous messageGo to next message
up
Re: model merging [message #1007953 is a reply to message #1007917] Fri, 08 February 2013 08:08 Go to previous messageGo to next message
Do you have things to really merge ? Like two times the same Class ?
In this case you'd rather do that in EMF directly.
Re: model merging [message #1008027 is a reply to message #1007953] Fri, 08 February 2013 10:05 Go to previous messageGo to next message
Thanks for the reply,
I really have things to merge.
As I explained, I have classes and stereotypes in model2 that are not present in model1. I would like to have those classes from model2 inserted in model1. Is it possible to do this in ATL?
Thaks in advance,
Claudio.
Re: model merging [message #1008068 is a reply to message #1008027] Fri, 08 February 2013 12:27 Go to previous messageGo to next message
Are things present in both models and should then become one single thing ? That's a real merge operation otherwise it's just a "sum" of the two models.
Re: model merging [message #1008114 is a reply to message #1008068] Sat, 09 February 2013 03:46 Go to previous messageGo to next message
Thanks for your reply,
only the profile application is the same for both models. For the rest they are tipically different classes. Does this make any difference from the ATL point of view?
Thanks in advance,
Claudio Persico
Re: model merging [message #1008164 is a reply to message #1008114] Mon, 11 February 2013 03:42 Go to previous messageGo to next message
Do that with the UML2 APIs then it will me much simpler.
Re: model merging [message #1008769 is a reply to message #1008114] Wed, 13 February 2013 15:25 Go to previous messageGo to next message
> point of view?
> Thanks in advance,
> Claudio Persico
You need to specify which element to copy into your output model in case there
are duplicates (i.e. occurrences in both input models).
In addition, copying stereotype applications is hard. EMFTVM makes this a bit
easier by allowing reflective copying of stereotype applications. That way you
can use a standard UML copy transformation:
http://soft.vub.ac.be/viewvc/UML2CaseStudies/uml2cs-transformations/transformations/UML2Copy.atl?view=markup
Note that the above transformation copies only a single input model. You'll
need to adapt each rule (by search-and-replace) to look like this:
rule Comment {
from s : UML2!"uml::Comment" (thisModule.inElements->includes(s))
and define thisModule.inElements like so:
helper def : inElements : Set(UML2!"ecore::EObject") =
UML2!"ecore::EObject".allInstancesFrom('IN')->union(
UML2!"ecore::EObject".allInstancesFrom('IN2'))->asSet();
This way, the transformation copies all elements from IN and IN2, but not PROFILE.
Dennis
Re: model merging [message #1008988 is a reply to message #1008769] Thu, 14 February 2013 03:57 Go to previous messageGo to next message
Thank you for your reply,
I'm trying to make it works with EMFTVM as Dennis nicely suggested. I successfully copied my classes from IN2 in IN1 but they appear outside the uml:model.
I would like to have classes from model 2 (IN2) belonging to uml:model of model 1 (IN1). Tipically I do this whit a resolveTemp, but this time I'm not able to do this.
Any suggestion?
Thank you in advance.
Claudio
Re: model merging [message #1009258 is a reply to message #1008164] Thu, 14 February 2013 14:17 Go to previous messageGo to next message
I suppose this is what you meant:
http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.uml2.doc%2Freferences%2Fjavadoc%2Forg%2Feclipse%2Fuml2%2Fuml%2Futil%2FUMLUtil.PackageMerger.html
That looks like a boxed solution to merge two packages (or models). Definitely
worth a try.
Dennis
Re: model merging [message #1009270 is a reply to message #1008988] Thu, 14 February 2013 14:50 Go to previous messageGo to next message
> uml:model.
> able to do this.
> Any suggestion?
> Claudio
So you indeed have duplicates which need sorting out:
- The two UML2!Model elements at the root of each model
- Each UML2!Package with the same (qualified) name in each model
You need to adapt your inElements helper and the Model and Package rules for this:
uses lib::UML2; -- get this from
http://soft.vub.ac.be/viewvc/UML2CaseStudies/uml2cs-transformations/transformations/lib/UML2.atl?view=markup
UML2!"ecore::EObject".allInstancesFrom('IN2')->select(e |
e.from('IN').oclIsUndefined()))->asSet();
helper context UML2!"ecore::EObject" def : from(model : String) :
UML2!"ecore::EObject" =
OclUndefined; -- base case: equivalent EObjects cannot be found back
helper context UML2!"uml::Package" def : from(model : String) :
UML2!"uml::Package" =
let packs : Sequence(UML2!"uml::Package") =
UML2!"uml::Package".allInstancesFrom(model)->select(p |
p.umlQualifiedName = self.umlQualifiedName)
in
if packs->isEmpty() then
OclUndefined
else
packs->first()
endif;
helper context UML2!"uml::Model" def : from(model : String) : UML2!"uml::Model" =
UML2!"uml::Model".allInstancesFrom(model)->first();
rule Model {
from s : UML2!"uml::Model" (thisModule.inElements->includes(s))
using {
s2 : UML2!"uml::Model" = s.from('IN2');
to t : UML2!"uml::Model" (
__xmiID__ <- s.__xmiID__,
name <- s.name,
visibility <- s.visibility,
viewpoint <- s.viewpoint,
eAnnotations <- s.eAnnotations,
ownedComment <- s.ownedComment,
clientDependency <- s.clientDependency,
nameExpression <- s.nameExpression,
elementImport <- s.elementImport,
packageImport <- s.packageImport,
ownedRule <- s.ownedRule,
templateParameter <- s.templateParameter,
templateBinding <- s.templateBinding,
ownedTemplateSignature <- s.ownedTemplateSignature,
packageMerge <- s.packageMerge,
packagedElement <- s.packagedElement->union(
if s2.oclIsUndefined() then
Sequence{}
else
s2.packagedElement->select(e | thisModule.inElements->includes(e))
endif),
profileApplication <- s.profileApplication)
rule Package {
from s : UML2!"uml::Package" in IN (s.oclIsTypeOf(UML2!"uml::Package")
and thisModule.inElements->includes(s))
using {
s2 : UML2!"uml::Package" = s.from('IN2');
to t : UML2!"uml::Package" (
name <- s.name,
Sequence{}
else
endif),
Here I've just started with packagedElement, but you may want to merge/filter
other containment references as well (e.g. profileApplication).
Dennis
Re: model merging [message #1009530 is a reply to message #1009270] Fri, 15 February 2013 04:28 Go to previous messageGo to next message
Thank you so much for your reply and efforts,
The UML2 API java are the last resort to me. I will try them lastly.
Meanwhile I've made this changes:
1) added libraries UML2 and Strings (referenced by UML2)
2) commented previous rules Model and Package
3) added new rules Model and Package you provided (thanks again)
4) modified helpers you provided because they give me an error. I think this is because the name of the helpers if "from", that is a keyword, so I modified this in "comesFrom" in the helper and obviously in all callings (is this correct?)
Now It gives me this error:
org.eclipse.m2m.atl.emftvm.util.VMException: java.lang.UnsupportedOperationException: UML2!Class::comesFrom(#native!java.lang.String)
at static EMFTVM!ExecEnv::inElements: Set (staticValue: null)@0#2(platform:/resource//ecore2locale/UML2Copy.atl#[207:116-207:133])
	Local variables: [e = _OB0ToGSkEeKEuaD-A95eUA:UML2!Class]
at public org.eclipse.m2m.atl.emftvm.util.LazyList org.eclipse.m2m.atl.emftvm.util.LazyList.select(org.eclipse.m2m.atl.emftvm.CodeBlock)
	Local variables: []
at static EMFTVM!ExecEnv::inElements: Set (staticValue: null)#9(platform:/resource//ecore2locale/UML2Copy.atl#[207:2-207:163])
	Local variables: []
at rule Model@matcher#3(platform:/resource//ecore2locale/UML2Copy.atl#[229:4-229:40])
	Local variables: [s: UML2!uml::Model = protections:UML2!Model]
at static EMFTVM!ExecEnv::main() : Object(platform:/resource//ecore2locale/UML2Copy.atl)
	Local variables: []
But I don't understand what this means.
Have I made something wrong?
Thank you in advance,
Claudio
Re: model merging [message #1009810 is a reply to message #1009530] Fri, 15 February 2013 14:10 Go to previous messageGo to next message
> correct?)
> Local variables: []
> Local variables: []
> at rule
> Local variables: []
> Claudio
Ah yes, I remember! UML2 got refactored such that its metaclasses no longer
inherit from EObject. You'll need to rewrite your helpers to use OclAny where
you specified EObject before (I called them equivFrom now):
helper context OclAny def : equivFrom(model : String) : OclAny =
helper context UML2!"uml::Package" def : equivFrom(model : String) :
in
OclUndefined
else
packs->first()
endif;
helper context UML2!"uml::Model" def : equivFrom(model : String) :
UML2!"uml::Model" =
Dennis
Re: model merging [message #1010024 is a reply to message #1009810] Sat, 16 February 2013 04:43 Go to previous message
This post is only to thank everyone who helped me. I finally got the transformation works.
I also modified the ApplyStereotypes rule to appear like this:
lazy rule ApplyStereotypes {
	from
		--s: UML2!"uml::Element" in IN
		s: UML2!"uml::Element" (thisModule.inElements -> includes(s))
	using {
		t: UML2!"uml::Element" = s.resolve();
	do {
		for (st in s.getAppliedStereotypes()) {
			t.applyStereotype(st);
			for (a in st.getAllAttributes()) {
				if (not a.name.startsWith('base_') and s.hasValue(st, a.name)) {
					t.setValue(st, a.name, s.getValue(st, a.name));
Thank you again, in particular to Dennis.
Claudio
Previous Topic:I need some help in ATL transformation when use KDM
Next Topic:Using external parameters in ATL
Current Time: Wed Jul 23 04:12:52 EDT 2025
Powered by FUDForum. Page generated in 0.33175 seconds
