Action Error: Point to click is outside of component [message #930969] |
Tue, 02 October 2012 16:11  |
I am using select ContextMenu entry by textpath Test Case on Linux Jubula Standalone, and I have the following error:
Error Description Point to click is outside of component
I was wondering why could the reason be for this error? What I am assuming is that the component I am about to select is not reachable, but I am not sure why this happens since I work with Jubula across different platforms, and I only see this happened on my Linux Machine.
Thanks in advance,
Oscar Trejo
[Updated on: Tue, 02 October 2012 16:20] by Moderator
Re: Action Error: Point to click is outside of component [message #1008095 is a reply to message #1008093] |
Fri, 08 February 2013 17:35   |
The workaround that I used was not very efficient (I also did not like it), but it worked and was the only way I had. I first select the item with the test case "left click", then "right click", and then use "action keys" (Up,left,right,down") until the destination is reached. Finally you simply press enter.
Like I said, I did not like that workaround because it was very slow! I am assuming you are trying to access a context menu option to open another window. If that is the case, before I actually you try my workaround. Try to see if you test application has a shortcut (meaning either by pressing a combination of keys or access it from other place) because that would be easier and faster. In my case, the software I was testing did not have such shortcut so I had to use my workaround.
Hope this helps,
Oscar Trejo
FUDForum. Page generated in 0.52119 seconds
