Home » Archived » Hudson » Error installing using yum on CentOS(Error installing using yum on CentOS)
Error installing using yum on CentOS [message #997685] Tue, 08 January 2013 09:48 Go to next message
I'm trying to install Hudson on CentOS 6.3 running as a Guest OS in VirtualBox on Windows 7.
I'm using the installation details from wiki.eclipse.org/Hudson-ci/Installing_Hudson_RPM
After I've executed the wget command and issue a yum check-update I get the following error;
hudson-ci.org/redhat/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404"
Any idea why this is happening? Is the repository for Hudson no longer available?
Trevor
PS I had to remove http from the URL's due to being a first time poster Sad
Re: Error installing using yum on CentOS [message #997748 is a reply to message #997685] Tue, 08 January 2013 12:01 Go to previous messageGo to next message
Hi Trevor,
Due to some unknown reason the repomd.xml was not copied properly to the Package repository location. I just made sure it was copied correctly now. Could you please try again.
Re: Error installing using yum on CentOS [message #998089 is a reply to message #997748] Wed, 09 January 2013 05:56 Go to previous messageGo to next message
Thanks Winston. That resolved the installation issue.
However the service now doesn't seem to run in the background and I had to stop it running as a service on startup to enable me to log into the server.
Any reason why it is doing this?
Trevor
Re: Error installing using yum on CentOS [message #998231 is a reply to message #998089] Wed, 09 January 2013 11:06 Go to previous messageGo to next message
Hi Trevor,
I looked at the RPM packaging source.
http://git.eclipse.org/c/hudson/org.eclipse.hudson.tools.packaging.git/tree/rpm/SOURCES/hudson.init.in
The RPM is supposed to create /etc/init.d/hudson with the following
echo -n "Starting Hudson "
daemon --user "$HUDSON_USER" --pidfile "$HUDSON_PID_FILE" $JAVA_CMD $PARAMS > /dev/null
As you can see the service is started as a deamon, so should be in the background. Could you check that file and see what it has.
Re: Error installing using yum on CentOS [message #998238 is a reply to message #998231] Wed, 09 January 2013 11:22 Go to previous messageGo to next message
Hi Winston,
Yes the file seems to have those two lines set in it, but I simply get "Starting Hudson" and then it just sits there and hangs the boot process.
I then have to set hudson to not start up automatically from single user mode before it will reboot succesfully.
Trevor
Re: Error installing using yum on CentOS [message #1006549 is a reply to message #998238] Thu, 31 January 2013 11:29 Go to previous messageGo to next message
I've returned to this problem to try and solve it. It would appear the issue is with this command in the file /etc/init.d/hudson;
If I change it to the following, removing > /dev/null it seems to execute fine;
daemon --user "$HUDSON_USER" --pidfile "$HUDSON_PID_FILE" $JAVA_CMD $PARAMS &
I also have to remove the /dev/null redirect from this command also, otherwise I get the same hanging problem.
echo "$cmd" | grep $HUDSON_WAR > /dev/null
Any ideas why having a redirect to /dev/null may be causing a hang during script execution?
I'm running under CentOS 6 in a VirtualBox VM.
Trevor Cole
Re: Error installing using yum on CentOS [message #1007670 is a reply to message #1006549] Wed, 06 February 2013 18:19 Go to previous messageGo to next message
Strange "daemon" is suppose to act similar to &. Anyway > /dev/null swallows all your log. Probably in order for your logs not to go in the console, you should do something like
daemon --user "$HUDSON_USER" --pidfile "$HUDSON_PID_FILE" $JAVA_CMD $PARAMS &> /var/tmp/hudson.log &
All the Hudson standard output and error will go to the log file /var/tmp/hudson.log which you can refer later.
Re: Error installing using yum on CentOS [message #1007852 is a reply to message #997685] Thu, 07 February 2013 12:55 Go to previous messageGo to next message
I've also noticed that the stop command only kills the root process while the other three created are left running. Any ideas on why this would be happening?
Re: Error installing using yum on CentOS [message #1007932 is a reply to message #1007670] Fri, 08 February 2013 04:51 Go to previous messageGo to next message
Winston Prakash wrote on Wed, 06 February 2013 18:19
Thanks Winston, that has solved the issue I was getting.
Trevor
Re: Error installing using yum on CentOS [message #1008052 is a reply to message #1007932] Fri, 08 February 2013 11:20 Go to previous messageGo to next message
I wound up re-writing that part of the init script. The nice thing is it only leaves a single process running. The only issue is that I haven't added a safety check for pid file existence to avoid double starting the service.
#daemon --user "$HUDSON_USER" --pidfile "$HUDSON_PID_FILE" $JAVA_CMD $PARAMS &> /dev/null &
runuser -s /bin/bash hudson -c "nohup $JAVA_CMD $PARAMS &> /dev/null &"
RETVAL=$?
if [ $RETVAL = 0 ]; then
success
echo > "$HUDSON_PID_FILE" # just in case we fail to find it
MY_SESSION_ID=`/bin/ps h -o sess -p $$`
# get PID
/bin/ps hww -u "$HUDSON_USER" -o sess,ppid,pid,cmd | \
while read sess ppid pid cmd; do
# [ "$ppid" = 1 ] || continue
# this test doesn't work because Hudson sets a new Session ID
# [ "$sess" = "$MY_SESSION_ID" ] || continue
echo "$cmd" | grep $HUDSON_WAR &> /dev/null &
[ $? = 0 ] || continue
# found a PID
echo $pid > "$HUDSON_PID_FILE"
done
else
failure
fi
Re: Error installing using yum on CentOS [message #1008057 is a reply to message #1008052] Fri, 08 February 2013 11:33 Go to previous messageGo to next message
@Terran, the sources I use to create the Linux distributions are here.
Would you mind to add your patch to it. Any one is welcome to provide patch via Eclipse Gerrit.
http://wiki.eclipse.org/Hudson-ci/development#Submitting_a_Patch_for_Non-Committers
Re: Error installing using yum on CentOS [message #1008061 is a reply to message #1008057] Fri, 08 February 2013 11:57 Go to previous message
Sure. I'll get it cleaned up and submitted.
Previous Topic:How to extract metrics from a report file
Next Topic:Error while building a grails app
Current Time: Wed Nov 05 14:09:04 EST 2025
Powered by FUDForum. Page generated in 0.05501 seconds
