Home » Eclipse Projects » NatTable » CellEditor on DoubleCLick?
CellEditor on DoubleCLick? [message #1008020] Thu, 07 February 2013 16:53 Go to next message
The cellEditor is triggered on leftclick now.
Is it possible to trigger it on double click?
Re: CellEditor on DoubleCLick? [message #1008386 is a reply to message #1008020] Tue, 12 February 2013 04:30 Go to previous message
You change the default edit bindings by finding the
DefaultEditBindings
And change it to your own and replace the single click binding by double click binding.
I did the same and mine looks like this: (I did some other changes as well to make sure that you also can edit with upper case and by pressing space)
public class ExtendedEditBindings extends AbstractUiBindingConfiguration {
	public void configureUiBindings(UiBindingRegistry uiBindingRegistry) {
		uiBindingRegistry.registerKeyBinding(new KeyEventMatcher(SWT.NONE, SWT.F2), new KeyEditAction());
		uiBindingRegistry.registerKeyBinding(new KeyEventMatcher(SWT.NONE, SWT.SPACE), new KeyEditAction());
		uiBindingRegistry.registerKeyBinding(new LetterOrDigitKeyEventMatcher(), new KeyEditAction());
		uiBindingRegistry.registerKeyBinding(new LetterOrDigitKeyEventMatcher(SWT.SHIFT), new KeyEditAction());
		uiBindingRegistry.registerDoubleClickBinding(new BodyCellEditorMouseEventMatcher(TextCellEditor.class), new MouseEditAction());
		uiBindingRegistry.registerDoubleClickBinding(new CellPainterMouseEventMatcher(
				GridRegion.BODY,
				MouseEventMatcher.LEFT_BUTTON,
				CheckBoxPainter.class), new MouseEditAction());
		uiBindingRegistry.registerDoubleClickBinding(new BodyCellEditorMouseEventMatcher(ComboBoxCellEditor.class), new MouseEditAction());
				new BodyCellEditorMouseEventMatcher(MultiComboBoxCellEditor.class),
Then find the DefaultGridLayerConfiguration change it to your own and add your own EditBindings
protected void addEditingUIConfig() {
	addConfiguration(new ExtendedEditBindings());
And use this as grid layer configuration
gridLayer.addConfiguration(new ExtendedGridLayerConfiguration(gridLayer));
[Updated on: Tue, 12 February 2013 04:31] by Moderator
Previous Topic:Scroll listener?
Next Topic:Re: Scroll listener?
Current Time: Fri Jul 18 22:56:13 EDT 2025
Powered by FUDForum. Page generated in 0.08483 seconds
