Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] RCP + Texo/XML REST Web service (Using RCP with Texo/XML RESTWeb service )
[Texo] RCP + Texo/XML REST Web service [message #1007730] Thu, 07 February 2013 05:49 Go to next message
I have an "RCP" application and I need to make use of "Texo/XML REST Web services" support. Is it possible with Texo ?
I went through the following wiki pages, but didn't find much on the above topic. Any thoughts/pointers ?
http://wiki.eclipse.org/Texo/JSON_REST_Web_Services
http://wiki.eclipse.org/Texo/XML_REST_Web_Services
http://wiki.eclipse.org/Texo/EMFResource
Thanks in advance.
[Updated on: Thu, 07 February 2013 05:50] by Moderator
Re: [Text] RCP + Texo/XML Rest Web service [message #1007733 is a reply to message #1007730] Thu, 07 February 2013 05:58 Go to previous messageGo to next message
Hi Neeraj,
For the RCP client-server connection Texo has the JSONTexoResource, it uses json which is more efficient than xml for
data transfer. See this blog for more information:
http://martintaal.wordpress.com/2012/08/30/taking-emf-to-the-third-tier-the-texo-json-resource/
The JSONTexoResource implements the standard EMF Resource api/interface, so you can use it instead of the other EMF
Resource implementations. The RCP client should not see any difference in api/interface/usage.
JSON is used for the client-server communication here. But the xml webservices is also there (on the server) if you want
to connect to the same server in a different way from another type of client.
gr. Martin
On 02/07/2013 11:49 AM, Neeraj Bhusare wrote:
> Hi
> I have an "RCP" application and I need to make use of "Texo/XML Rest Web services" support. Is it possible with Texo ?
> Thanks in advance.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Text] RCP + Texo/XML Rest Web service [message #1007758 is a reply to message #1007733] Thu, 07 February 2013 07:28 Go to previous messageGo to next message
Thanks. Let me take a look at the link. Also, is this the right example for RCP/JSON (3-tier architecture) - org.eclipse.emf.texo.example1.rcp ?
[Updated on: Thu, 07 February 2013 07:29] by Moderator
Re: [Text] RCP + Texo/XML Rest Web service [message #1007765 is a reply to message #1007758] Thu, 07 February 2013 07:52 Go to previous messageGo to next message
Hi Neeraj,
No not a good link I am afraid. I am kind of looking for someone to develop an example rcp with my help...
gr. Martin
On 02/07/2013 01:28 PM, Neeraj Bhusare wrote:
> Thanks. Let me take a look at the link. Also, is this the right example for RCP/JSON -
> https://github.com/mtaal/texo/tree/master/org.eclipse.emf.texo.example1.rcp ?
The Netherlands
Re: [Text] RCP + Texo/XML Rest Web service [message #1007771 is a reply to message #1007765] Thu, 07 February 2013 08:20 Go to previous messageGo to next message
Thanks Martin. Let me give it a try. If I succeed, I'll contribute my work as an example.
Re: [Text] RCP + Texo/XML Rest Web service [message #1007775 is a reply to message #1007771] Thu, 07 February 2013 08:28 Go to previous messageGo to next message
Just out of curiosity, what is the use of the "org.eclipse.emf.texo.example1.rcp" example ?
Re: [Text] RCP + Texo/XML Rest Web service [message #1007792 is a reply to message #1007775] Thu, 07 February 2013 09:01 Go to previous message
It was a demo rcp I started with someone else but he moved on to other things. I am myself more into web developments
(client and server) so it is difficult for me to develop a RCP client (never done that...) even as a demo.
So I am looking for a nice contained/focused demo RCP which shows how to do client side RCP with server side Texo. I can
do the wiki/video to show how it works but I need a real RCP developer to do the front end in the standard/default way...
gr. Martin
The Netherlands
Previous Topic:[Text] RCP + Text/XML Rest Web service
Next Topic:[Texo] Charset conversion errors inside xpt and xtend files
Current Time: Sat Jul 26 08:46:51 EDT 2025
Powered by FUDForum. Page generated in 0.05909 seconds
