| Re: SMI (ASN1) grammar [message #1007977 is a reply to message #1007711] |
Fri, 08 February 2013 02:24    |
Eclipse User  |
Hi Christophe,
those token definitions can be translates as plain keywords.
 >> I will be facing more of these issues, and need help.
See the footer ;-)
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 07.02.13 09:48, schrieb Christophe Bouhier:
> Hello There,
> I am creating an editor for the SMI format. See:
> http://en.wikipedia.org/wiki/Structure_of_Management_Information
> It's used to define so called MIB's used by the SNMP protocol. The SMI
> format is based on ASN1. There is a antlr version of the grammar as a
> starting point, but that is horrifically intimidating :)
> http://www.antlr3.org/grammar/1105770765162/parsesmi-v1-15jan05.zip
> Does anyone has a base ASN1 Xtext grammar or even better SMI? If not,
> would anyone like to cooperate on this? Or help translate the antlr
> grammar?
> For example in ANTLR, this grammar as a bunch of tokens as :
> tokens {
> ABSENT_KW = "ABSENT" ;
> ABSTRACT_SYNTAX_KW = "ABSTRACT-SYNTAX" ;
> ALL_KW= "ALL" ;
> ANY_KW = "ANY" ;
> ARGUMENT_KW = "ARGUMENT" ;
> APPLICATION_KW = "APPLICATION" ;
> AUTOMATIC_KW = "AUTOMATIC" ;
> BASED_NUM_KW = "BASEDNUM" ;
> BEGIN_KW = "BEGIN" ;
> BIT_KW = "BIT" ;
> BMP_STRING_KW = "BMPString" ;
> How do I convert this to Xtext? Are these literals which can be put in
> an enum? I will be facing more of these issues, and need help.
> Thank You. Christophe Bouhier
FUDForum. Page generated in 0.04166 seconds
