Home » Modeling » EMF » [CDO] importer Exception
[CDO] importer Exception [message #1007597] Wed, 06 February 2013 11:51 Go to next message
See the exception when importing an xml file exported by CDO.
Does CDO produce XML it can not import later on?
here is a snippet of the produced XML:
<feature name="message" value="Could not locate identifier for metric STP_SCPKTSNT. For identifiers:  - NODE: arnstp01 - FUNCTION: &lt;=�����, Failed on :  - FUNCTION: &lt;=�����"/>
That's bizar encoding, this value.
This is the code which writes this feature:
final StringBuilder sb = new StringBuilder();
		sb.append("Could not locate networkElement for metric "
				+ metric.getName());
		sb.append("Using identifiers: ");
		for (final IComponentLocator.IdentifierDescriptor idValue : identifierValues) {
			sb.append(" - " + idValue.getKind().getObjectKind().getName()
					+ ": " + idValue.getValue());
Anything unusual?
org.xml.sax.SAXParseException: Character reference "&#1" is an invalid XML character.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:195)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:174)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:388)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1414)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanCharReferenceValue(XMLScanner.java:1298)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanAttributeValue(XMLScanner.java:851)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanAttribute(XMLDocumentFragmentScannerImpl.java:1547)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1320)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2756)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:648)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:511)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:198)
at org.eclipse.emf.cdo.server.CDOServerImporter$XML.importAll(CDOServerImporter.java:329)
at org.eclipse.emf.cdo.server.CDOServerImporter.importRepository(CDOServerImporter.java:111)
at org.eclipse.emf.cdo.internal.server.bundle.CDOCommandProvider.importXML(CDOCommandProvider.java:230)
at org.eclipse.emf.cdo.internal.server.bundle.CDOCommandProvider._cdo(CDOCommandProvider.java:110)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.osgi.framework.internal.core.FrameworkCommandInterpreter.execute(FrameworkCommandInterpreter.java:209)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.docommand(FrameworkConsole.java:155)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.runConsole(FrameworkConsole.java:140)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.run(FrameworkConsole.java:104)
at java.lang.Thread.run(Thread.java:662)
Re: [CDO] importer Exception [message #1007641 is a reply to message #1007597] Wed, 06 February 2013 15:47 Go to previous messageGo to next message
Am 06.02.2013 17:51, schrieb Christophe Bouhier:
> See the exception when importing an xml file exported by CDO. Does CDO produce XML it can not import later on?
That's not the goal :P
> - FUNCTION: <=�����, Failed on : - FUNCTION: <=�����"/>
Hm, is "<" allowed in attribute values?
I checked that the exporter uses this to output the XML:
SAXTransformerFactory factory = (SAXTransformerFactory)SAXTransformerFactory.newInstance();
xmlHandler = factory.newTransformerHandler();
So, all needed conversion and escaping should be done there. I'm not an expert in XML or SAX. Maybe Ed has an idea...
Cheers
/Eike
http://www.esc-net.de
> Anything unusual?
> at
> at
> at
> at
> at
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
Re: [CDO] importer Exception [message #1007644 is a reply to message #1007597] Wed, 06 February 2013 16:05 Go to previous messageGo to next message
It looks like a very normal non 8-bit to 8-bit character coding mismatch.
You created a Java string, but what did you do with it then?
Ed Willink
Re: [CDO] importer Exception [message #1007665 is a reply to message #1007641] Wed, 06 February 2013 17:51 Go to previous messageGo to next message
XML 1.0 does not allow as many characters as does XML 1.1 so maybe
specifying OPTION_XML_VERSION as 1.1 will allow the characters you've
included. Note that even XML 1.1 doesn't allow &#0;. I'd definitely
expect any < in the string to be encoded as &lt;...
>> Hi,
>> identifierValues) {
>> sb.append(" - " +
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Anything unusual?
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
Re: [CDO] importer Exception [message #1007708 is a reply to message #1007665] Thu, 07 February 2013 03:35 Go to previous message
The snippet of XML, is also decoded by the forum! The '<' is not the problem. In my snippet it's a "&lt;"
The problem occurs on this character "" (As you see in the exception). It's indeed an invalid XML 1.0 control character.
I submitted this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=400182
Cheers Christophe
Previous Topic:[CDO] NPE exporting from CDO
Next Topic:[Teneo] EntityInterfaceNameStrategy not setting Enumerations as expected
Current Time: Fri Jul 25 21:03:12 EDT 2025
Powered by FUDForum. Page generated in 0.06377 seconds
