Home » Language IDEs » Java Development Tools (JDT) » Question about Eclipse / Maven and Kerberos authentication
Question about Eclipse / Maven and Kerberos authentication [message #1007584] Wed, 06 February 2013 10:16 Go to next message
I am trying to find a solution for the following problem:
Our developers who use Eclipse want to connect to Maven repository from our company network.
As Maven repository can be anywhere in the world (any IP) and we can only allow connection to IP address (not hosts, like maven.apache.org). We don't want to allow connection to any ip in the world, just only specific ip addresses.
As it is not possible, that is why would like to control the connection with our proxy. We don't want to install Maven proxy.
I would like to know if Eclipse can handle / support any kind of authetication like NTLM or Kerberos (Kerberos prefered).
Thank you.
Re: Question about Eclipse / Maven and Kerberos authentication [message #1007612 is a reply to message #1007584] Wed, 06 February 2013 12:53 Go to previous messageGo to next message
JDT never connects to Maven repositories.
If you're using Maven from Eclipse, you're likely to use m2e for that purpose, so perhaps the m2e mailing list can get you an answer, but from how I understand the architecture, also m2e only delegates to Maven - so questions of how Maven accesses remote repositores are just Maven questions (might be as simple as setting your proxy as the only repository in your Maven settings.xml??)
best,
Stephan
Re: Question about Eclipse / Maven and Kerberos authentication [message #1007689 is a reply to message #1007612] Thu, 07 February 2013 01:37 Go to previous message
Dear Stephan,
I will try, thank you.
Previous Topic:Multiple selection in Package Explorer on Ubuntu / Linux
Next Topic:"Extract method object" in eclipse?
Current Time: Thu Jul 24 21:36:22 EDT 2025
Powered by FUDForum. Page generated in 0.16702 seconds
