Home » Archived » Jubula » Extension with Jubula 1.3.0
Extension with Jubula 1.3.0 [message #1007554] Wed, 06 February 2013 07:48 Go to next message
I read this Tutorial(subshell.com/en/subshell/blog/Extending-Jubula-For-Custom-SWT-Controls-In-RCP-Applications100.html) how to extending Jubula.
I copied the "com.subshell.jubula.extension.rcp.aut_1.2.0.201204031506.jar" in the plugin directory of the AUT
and
the "com.subshell.jubula.extension.client_1.2.0.201204031506.jar" in the plugin directory of jubula(jubula_1.3.00071\jubula\plugins.
Next I add the line "com.subshell.jubula.extension.client,1.2.0.201204031506,plugins/com.subshell.jubula.extension.client_1.2.0.201204031506.jar,4,false" to the "<jubula-install-directory>\jubula\configuration\org.eclipse.equinox.simpleconfigurator\bundles.info"
Finally I restart Jubula, but I cant find the new extension...
When I add a new Test Step in the opening dialog I should be able to select the test action "Verify Control Data" for the component type "Control". But there is no "Control" or "Verify Control Data".
Can you tell me what I did wrong?
Thanks.
[Updated on: Wed, 06 February 2013 07:49] by Moderator
Re: Extension with Jubula 1.3.0 [message #1007907 is a reply to message #1007554] Fri, 08 February 2013 01:47 Go to previous messageGo to next message
As I don't write extensions, the help I can offer is to add some links to other places where the topic has been discussed:
http://www.eclipse.org/forums/index.php/t/261926/
https://bugs.eclipse.org/bugs/show_bug.cgi?id=372349
http://www.eclipse.org/forums/index.php/t/323430/
http://www.eclipse.org/forums/index.php/t/318379/
Alex
Re: Extension with Jubula 1.3.0 [message #1008168 is a reply to message #1007554] Mon, 11 February 2013 04:06 Go to previous messageGo to next message
I found my mistake:
The selection for the "Toolkit for Test Specification" was wrong.
I chose "concrete", but the correct Toolkit for this tutorial/plug-in is "rcp".
Re: Extension with Jubula 1.3.0 [message #1008367 is a reply to message #1008168] Tue, 12 February 2013 03:10 Go to previous messageGo to next message
Thanks for posting the solution!
Re: Extension with Jubula 1.3.0 [message #1234954 is a reply to message #1008367] Thu, 23 January 2014 03:04 Go to previous message
Alexandra Schladebeck wrote on Tue, 12 February 2013 03:10
I tried you said step-to-step,Jubula can work and hanvn't any errors,but I cann't map the ImageHyperlink Component.
I hope Someone can help me. Sad
Previous Topic:Error by trying to run a test Job under linux
Next Topic:Extend Jubula for ImageHyperlink
Current Time: Sat Jul 26 08:58:07 EDT 2025
Powered by FUDForum. Page generated in 0.07567 seconds
