Home » Modeling » TMF (Xtext) » How to replace XtextDocument in the editor with a projection of it
How to replace XtextDocument in the editor with a projection of it [message #1007535] Wed, 06 February 2013 05:55 Go to next message
Hi Smile
Given an editor opened for my DSL language, I can generate a ProjectionDocument which is a projection of the master document (that opened in the editor), and where in particular I remove some portions of text.
Now, I'd like to "substitute" the master document in the editor with its projection, making it editable for the user; in other words, I want to give the user an action which limits his possible editing of the document to the projected text.
I tried implementing a UI action with this code:
public class MyHandler extends AbstractHandler implements IHandler {
  public Object execute(ExecutionEvent event) throws ExecutionException {
    XtextEditor xtextEditor = (XtextEditor) HandlerUtil.getActiveEditor(event);
    IXtextDocument masterDocument = xtextEditor.getDocument();
    ProjectionDocumentManager manager = new ProjectionDocumentManager();
    ProjectionDocument projectedDocument = (ProjectionDocument) manager.createSlaveDocument(masterDocument);
    try {
      projectedDocument.addMasterDocumentRange(0, masterDocument.getLength());
    } catch (BadLocationException e1) {
      e1.printStackTrace();
    //...remove some portions of text from projected document using removeMasterDocumentRange...
    ISourceViewer sourceViewer = xtextEditor.getInternalSourceViewer();
    sourceViewer.setDocument(projectedDocument);
    return null;
This code generates a ClassCastException:
org.eclipse.e4.core.di.InjectionException: java.lang.ClassCastException: org.eclipse.jface.text.projection.ProjectionDocument cannot be cast to org.eclipse.xtext.ui.editor.model.XtextDocument
Taking a look to the API, I saw that in fact XtextDocument and ProjectionDocument are independent subclasses of AbstractDocument. So, a XtextDocument is not a ProjectionDocument and vice versa, but surely a XtextEditor supports folding and projection in general: I see that XtextSourceViewer extends ProjectionViewer.
I also tried to use the static method "get" in XtextDocumentUtil to obtain a XtextDocument given a ProjectionDocument, but in this way I still see the complete document in the editor!
Please help me! Have you any code example or suggestions? Rolling Eyes
Bye,
Marco
Re: How to replace XtextDocument in the editor with a projection of it [message #1007976 is a reply to message #1007535] Fri, 08 February 2013 02:22 Go to previous messageGo to next message
Hi Marco,
you may want to hook into
org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createDocument(Object)
Your projection document will have to implement IXtextDocument. Your
handler could then use the projection-enabled document to trigger
whatever you try to do there.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 06.02.13 11:55, schrieb Marco Naddeo:
> Hi :)
> text.
> @Override
> try {
> return null;
> Please help me! Have you any code example or suggestions? :roll:
> Bye,
> Marco
Re: How to replace XtextDocument in the editor with a projection of it [message #1008605 is a reply to message #1007976] Wed, 13 February 2013 04:25 Go to previous messageGo to next message
Sebastian Zarnekow wrote on Fri, 08 February 2013 02:22
Hi Marco,
Sebastian
Sorry I don't understand how I can hook into that protected method... by subclassing the class XtextDocumentProvider? Sad
Re: How to replace XtextDocument in the editor with a projection of it [message #1008781 is a reply to message #1008605] Wed, 13 February 2013 15:56 Go to previous messageGo to next message
a simple subclass and a straight forward binding should do the trick
public Class<? extends XtextDocumentProvider> bindXtextDocumentProvider() {
		return MyXDP.class;
~Christian
Re: How to replace XtextDocument in the editor with a projection of it [message #1009074 is a reply to message #1008781] Thu, 14 February 2013 06:33 Go to previous message
Thank you, Christian! Smile
The problem now is that the XtextDocumentProvider code contains some casts to XtextDocument (class, not interface), so I'm worry that implementing the interface IXtextDocument for my projection document does not solve the ClassCastException problem, I say right? Rolling Eyes
But I also have another doubt: how a XtextEditor supports code folding without relying on a ProjectionDocument? In other words, is there perhaps another way to hook my projection code without directly instantiate a ProjectionDocument?
Which is the easiest way to obtain what I want (hide some portions of text in a XtextEditor on request and so limit the user interaction to the displayed text)?
Previous Topic:Strange Exception thrown in JUNIT test
Next Topic:Import And Scoping
Current Time: Sat Jul 26 10:52:58 EDT 2025
Powered by FUDForum. Page generated in 0.08005 seconds
