Home » Archived » Hudson » Hudson 3.0 and Copy artifacts plugin issue
Hudson 3.0 and Copy artifacts plugin issue [message #1007266] Tue, 05 February 2013 05:06 Go to next message
it seems that "Copy artifacts plugin" does not behave correctly after migration to Hudson 3.0.0 from 2.2.0, it copies almost everything (but I don't notice what exactly) and not only artifacts that are archived.
The plugin version that I'm using is 1.23-h-1 and it seems to be the latest version.
Hudson proposes to downgrade to 1.12, can it be the right thing to do?
I'm not sure where to report this issue. Is it a plugin hosted at Eclipse?
Re: Hudson 3.0 and Copy artifacts plugin issue [message #1007331 is a reply to message #1007266] Tue, 05 February 2013 09:47 Go to previous messageGo to next message
I'm wondering if this is similar to https://github.com/hudson3-plugins/copyartifact-plugin/issues/1. I tried several tests on my local environment and found no issues. What settings do you have for the copy-artifact job(s)?
We host the plugins on https://github.com/hudson3-plugins.
Re: Hudson 3.0 and Copy artifacts plugin issue [message #1007336 is a reply to message #1007331] Tue, 05 February 2013 10:04 Go to previous messageGo to next message
effectively, it is the same issue.
For my configuration:
I specified a project name
Which build --> Latest successful build
I can specify target directory or not, same behavior
I can enable Flatten directories or not, same behavior
Hudson is running on Java 1.6:
java version "1.6.0_24"
OpenJDK Runtime Environment (IcedTea6 1.11.5) (6b24-1.11.5-0ubuntu1~10.04.2)
OpenJDK 64-Bit Server VM (build 20.0-b12, mixed mode)
Re: Hudson 3.0 and Copy artifacts plugin issue [message #1007346 is a reply to message #1007336] Tue, 05 February 2013 10:30 Go to previous messageGo to next message
sorry for double-posting but:
I downgraded the plugin to 1.12 version and it is working.
But in log I have the following error several times when loading the plugin at startup:
Feb 5, 2013 12:15:53 PM hudson.util.RobustCollectionConverter populateCollection
WARNING: Failed to resolve class hudson.plugins.copyartifact.CopyArtifact$EnvAction
It seems that there is no bad effect on my jobs even with these stacks.
Re: Hudson 3.0 and Copy artifacts plugin issue [message #1007660 is a reply to message #1007346] Wed, 06 February 2013 17:27 Go to previous messageGo to next message
Ok, I will take a look at what is going on between 1.12 & 1.23-h-1
Re: Hudson 3.0 and Copy artifacts plugin issue [message #1007893 is a reply to message #1007660] Thu, 07 February 2013 20:13 Go to previous messageGo to next message
I just released version 1.25-h-1. Let me know if that fixes the issues.
Re: Hudson 3.0 and Copy artifacts plugin issue [message #1015618 is a reply to message #1007893] Fri, 01 March 2013 07:05 Go to previous message
Hi Winston,
it fixes the issue.
Previous Topic:Evaluation
Next Topic:utter newbie user cannot login
Current Time: Sun Jul 20 20:25:32 EDT 2025
Powered by FUDForum. Page generated in 0.04861 seconds
