Home » Modeling » TMF (Xtext) » Strange Xtext error
Strange Xtext error [message #1007296] Tue, 05 February 2013 07:23 Go to next message
I have two plugins A and B :
- A contains an ecore model mmA.ecore that defines a single EClass named classA
- B depends on plugin A and contains an ecore model mmB.ecore that defines
an EClass named classB with classA as its superclass.
I build these two plugins and install them in the running eclipse.
In a separate workspace. initially empty, and using the eclipse in which plugins A
and B have been installed, I create a third plugin C, with an ecore model mmC.ecore
that defines a class named classC, the superclass of which is classB.
As soon as I add the Xtext nature to the project of plugin C, there is a error that
appears in the Problems view :
The feature 'eAllSuperTypes' of 'org.eclipse.emf.ecore.impl.EClassImpl@43b8d0fa{platform:/resource/pluginC/model/mmC.ecore#//classC}'
contains an unresolved proxy
'org.eclipse.emf.ecore.impl.EClassImpl@58c50c93{archive:file:/<absolute-path-of-the-eclipse-installation>/plugins/pluginB_1.0.0.201302050856.jar!/../pluginA/model/mmA.ecore#//classA}'
What's going wrong ?
Eclipse if juno SR1, and Xtext is version 2.3.1.v201208210947
Thanks for any hint.
Nicolas.
Re: Strange Xtext error [message #1007317 is a reply to message #1007296] Tue, 05 February 2013 08:53 Go to previous message
The problem is that the Ecore editor uses relative URIs to refer to
EModelElements in other ecore files. This doesn't work with Xtext once
they are installed. As a workaround, open your Ecore files with a text
editor and replace all relative URIs with platform resource URIs, e.g.
by replacing all occurrences of "../../" with "platform:/resource/"
before exporting and installing the plug-ins. The bad thing is, you have
to fix all these URIs ever time you have saved an Ecore editor with the
resource loaded.
Am 05.02.13 13:23, schrieb Nicolas:
> classA
> plugins A
> model mmC.ecore
> error that
> Nicolas.
Previous Topic:Documentation View
Next Topic:Adding static imports to XExpressions scope
Current Time: Fri Jul 25 22:26:27 EDT 2025
Powered by FUDForum. Page generated in 0.26549 seconds
