Connect to Microsoft Access via Data Explorer in IDE [message #1007209] |
Mon, 04 February 2013 19:30  |
Greetings all,
I am evaluating Eclipse for use in my organization. I need to use multiple data sources, including MS Access. I cannot find any information on how to use Microsoft Access via the IDE, just how to do it via code. I understand there is a JDBC-ODBC bridge that is apparently bundled with Eclipse, but I don't know how to add the driver so that I can select it when adding a new data source, or if this is even the way to go about it. I have virtually no experience, with Eclipse, Java, or Tomcat, so I really need some thorough information as to where to click, what to type, etc. Any help will be greatly appreciated!
Thanks!
Re: Connect to Microsoft Access via Data Explorer in IDE [message #1007333 is a reply to message #1007209] |
Tue, 05 February 2013 09:49   |
On 2/5/2013 6:52 AM, Sean Westerfield wrote:
> Greetings all,
> appreciated!
> Thanks!
There's a separate forum for Eclipse data tools where you might get more
and better help with this.
Re: Connect to Microsoft Access via Data Explorer in IDE [message #1007414 is a reply to message #1007376] |
Tue, 05 February 2013 13:46  |
On 2/5/2013 9:35 AM, Sean Westerfield wrote:
> Thanks for your reply! I don't see an data tools forum. I do see a
> BIRT forum which I guess might be more appropriate. I just figured this
> was a total newb question.
> I don't want to cross post, do you know how I can delete this post?
No, it's not that forum. The NNTP name is eclipse.dtp.
FUDForum. Page generated in 0.09858 seconds
