Home » Modeling » EMF » Copy EObject with eOpposite refs
Copy EObject with eOpposite refs [message #1007128] Mon, 04 February 2013 09:56 Go to next message
Do you know of a ('simple') way to copy EObjects with eOpposite refs?
I am aware of eOpposite refs that would change the container. That is ok for my use case.
The javadocs of org.eclipse.emf.ecore.util.EcoreUtil.Copier.copyReference(EReference, EObject, EObject) say:
Called to handle the copying of a cross reference; this adds values or sets a single value as appropriate for the multiplicity while omitting any bidirectional reference that isn't in the copy map.
Is it sufficient to manually 'extend' the copy map?
I just ended up with this copy function:
  private Collection<EObject> copyAll(Collection<EObject> objectsToCopy,
      final boolean includeEopposites) {
    EcoreUtil.Copier copier = new Copier() {
      private static final long serialVersionUID = 1L;
      public EObject get(Object key) {
        EObject eObject = super.get(key);
        if (eObject == null && includeEopposites) {
          if (key instanceof EObject) {
            eObject = (EObject) key;
        return eObject;
    Collection<EObject> copyAll = copier.copyAll(objectsToCopy);
    copier.copyReferences();
    return copyAll;
It seems to work for some EObjects with eOpposite refs but with others I get:
java.util.ConcurrentModificationException
	at org.eclipse.emf.common.util.AbstractEList$EIterator.checkModCount(AbstractEList.java:756)
	at org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(AbstractEList.java:710)
	at org.eclipse.emf.common.util.AbstractEList$EIterator.next(AbstractEList.java:690)
	at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReference(EcoreUtil.java:717)
	at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReferences(EcoreUtil.java:641)
Re: Copy EObject with eOpposite refs [message #1007132 is a reply to message #1007128] Mon, 04 February 2013 10:06 Go to previous messageGo to next message
Erdal,
Comments below.
> ok for my use case.
I doubt it's okay. How can it possibly be okay?
> The javadocs of
> @Override
> return eObject;
> return copyAll;
> I get:
> at
> at
> at
> at
> at
That's not surprising given that you're adding references to the
original list while iterating over it. Before I explain what you'd need
to do, I'd prefer you explain why you think it's okay for the original
object to be modified...
Re: Copy EObject with eOpposite refs [message #1007135 is a reply to message #1007132] Mon, 04 February 2013 10:23 Go to previous messageGo to next message
Imaginary model:
EClass Master
- details: Detail 0..* (eOpposite = true, containment = true)
EClass Detail
- master: Master (eOpposite = true, container = true)
Just imagine a master/detail UI where the details of the master are shown in a table.
If I select one of the details and copy it to the details list of the master, then, I think, it is ok to let the master know of its new detail.
Maybe, I missed something...
Ed Merks wrote on Mon, 04 February 2013 16:06
Erdal,
Comments below.
> ok for my use case.
> The javadocs of
> @Override
> return eObject;
> return copyAll;
> I get:
> at
> at
> at
> at
> at
Re: Copy EObject with eOpposite refs [message #1007151 is a reply to message #1007135] Mon, 04 February 2013 10:49 Go to previous messageGo to next message
Erdal,
Comments below.
On 04/02/2013 4:23 PM, Erdal Karaca wrote:
> Imaginary model:
> EClass Master
> EClass Detail
> shown in a table.
It's not a good example because it's a containment reference...
If you're doing this in the IDE you need a command to modify the state
of the original model otherwise undo will be broken... That would be
true even for a non-containment reference example. Think about how
badly behaved your scenario (it it weren't a containment) would be if
you copied the Master object. All Details would be removed from the
original and added to the copy; that can't possibly be a good thing, right?
>> Erdal,
>> Comments below.
>> is > ok for my use case.
>> > The javadocs of >
>> or > sets a single value as appropriate for the multiplicity while
>> omitting > any bidirectional reference that isn't in the copy map.
>> objectsToCopy,
>> > @Override
>> > return eObject;
>> > return copyAll;
>> others > I get:
>> > at >
>> > at >
>> > at >
>> > at >
>> > at >
>> need to do, I'd prefer you explain why you think it's okay for the
>> original object to be modified...
Re: Copy EObject with eOpposite refs [message #1007154 is a reply to message #1007151] Mon, 04 February 2013 11:00 Go to previous messageGo to next message
Yes, you are right... Anyways, what would be the solution? It (the code) is for educational purposes (dont do this) Smile
Ed Merks wrote on Mon, 04 February 2013 16:49
Re: Copy EObject with eOpposite refs [message #1007160 is a reply to message #1007154] Mon, 04 February 2013 11:10 Go to previous messageGo to next message
Erdal,
You'd need to specialize copyReference. Essentially copying the whole
method and changing the parts the filter out the things you want copied
anyway. You'll need to make a copy of the bidirectional list you're
iterator over that's changing during the iteration and iterate over that
copy.
> code) is for educational purposes (dont do this) :)
>> the > master, then, I think, it is ok to let the master know of its
>> new detail.
>> state of the original model otherwise undo will be broken... That
>> would be true even for a non-containment reference example. Think
>> about how badly behaved your scenario (it it weren't a containment)
>> would be if you copied the Master object. All Details would be
>> removed from the original and added to the copy; that can't possibly
Re: Copy EObject with eOpposite refs [message #1007166 is a reply to message #1007160] Mon, 04 February 2013 11:27 Go to previous message
Thanks, Ed! It works... but it is really ugly, so dont do this at home!
Ed Merks wrote on Mon, 04 February 2013 17:10
copy.
Previous Topic:How to implement an interface in Ecore Model Editor
Next Topic:[CDO][Teneo] How to write / read LOB data stream based?
Current Time: Sun Jul 27 22:22:15 EDT 2025
Powered by FUDForum. Page generated in 0.04139 seconds
