Copy EObject with eOpposite refs [message #1007128] |
Mon, 04 February 2013 09:56  |
Do you know of a ('simple') way to copy EObjects with eOpposite refs?
I am aware of eOpposite refs that would change the container. That is ok for my use case.
The javadocs of org.eclipse.emf.ecore.util.EcoreUtil.Copier.copyReference(EReference, EObject, EObject) say:
Called to handle the copying of a cross reference; this adds values or sets a single value as appropriate for the multiplicity while omitting any bidirectional reference that isn't in the copy map.
Is it sufficient to manually 'extend' the copy map?
I just ended up with this copy function:
private Collection<EObject> copyAll(Collection<EObject> objectsToCopy,
final boolean includeEopposites) {
EcoreUtil.Copier copier = new Copier() {
private static final long serialVersionUID = 1L;
public EObject get(Object key) {
EObject eObject = super.get(key);
if (eObject == null && includeEopposites) {
if (key instanceof EObject) {
eObject = (EObject) key;
return eObject;
Collection<EObject> copyAll = copier.copyAll(objectsToCopy);
copier.copyReferences();
return copyAll;
It seems to work for some EObjects with eOpposite refs but with others I get:
java.util.ConcurrentModificationException
at org.eclipse.emf.common.util.AbstractEList$EIterator.checkModCount(AbstractEList.java:756)
at org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(AbstractEList.java:710)
at org.eclipse.emf.common.util.AbstractEList$EIterator.next(AbstractEList.java:690)
at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReference(EcoreUtil.java:717)
at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReferences(EcoreUtil.java:641)
Re: Copy EObject with eOpposite refs [message #1007135 is a reply to message #1007132] |
Mon, 04 February 2013 10:23   |
Imaginary model:
EClass Master
- details: Detail 0..* (eOpposite = true, containment = true)
EClass Detail
- master: Master (eOpposite = true, container = true)
Just imagine a master/detail UI where the details of the master are shown in a table.
If I select one of the details and copy it to the details list of the master, then, I think, it is ok to let the master know of its new detail.
Maybe, I missed something...
Ed Merks wrote on Mon, 04 February 2013 16:06Erdal,
Comments below.
> ok for my use case.
I doubt it's okay. How can it possibly be okay?
> The javadocs of
> @Override
> return eObject;
> return copyAll;
> I get:
> at
> at
> at
> at
> at
That's not surprising given that you're adding references to the
original list while iterating over it. Before I explain what you'd need
to do, I'd prefer you explain why you think it's okay for the original
object to be modified...
Re: Copy EObject with eOpposite refs [message #1007151 is a reply to message #1007135] |
Mon, 04 February 2013 10:49   |
Erdal,
Comments below.
On 04/02/2013 4:23 PM, Erdal Karaca wrote:
> Imaginary model:
> EClass Master
> EClass Detail
> shown in a table.
It's not a good example because it's a containment reference...
If you're doing this in the IDE you need a command to modify the state
of the original model otherwise undo will be broken... That would be
true even for a non-containment reference example. Think about how
badly behaved your scenario (it it weren't a containment) would be if
you copied the Master object. All Details would be removed from the
original and added to the copy; that can't possibly be a good thing, right?
>> Erdal,
>> Comments below.
>> is > ok for my use case.
>> > The javadocs of >
>> or > sets a single value as appropriate for the multiplicity while
>> omitting > any bidirectional reference that isn't in the copy map.
>> objectsToCopy,
>> > @Override
>> > return eObject;
>> > return copyAll;
>> others > I get:
>> > at >
>> > at >
>> > at >
>> > at >
>> > at >
>> need to do, I'd prefer you explain why you think it's okay for the
>> original object to be modified...
Re: Copy EObject with eOpposite refs [message #1007160 is a reply to message #1007154] |
Mon, 04 February 2013 11:10   |
Erdal,
You'd need to specialize copyReference. Essentially copying the whole
method and changing the parts the filter out the things you want copied
anyway. You'll need to make a copy of the bidirectional list you're
iterator over that's changing during the iteration and iterate over that
copy.
On 04/02/2013 5:00 PM, Erdal Karaca wrote:
> Yes, you are right... Anyways, what would be the solution? It (the
> code) is for educational purposes (dont do this) :)
> Ed Merks wrote on Mon, 04 February 2013 16:49
>> the > master, then, I think, it is ok to let the master know of its
>> new detail.
>> state of the original model otherwise undo will be broken... That
>> would be true even for a non-containment reference example. Think
>> about how badly behaved your scenario (it it weren't a containment)
>> would be if you copied the Master object. All Details would be
>> removed from the original and added to the copy; that can't possibly
Re: Copy EObject with eOpposite refs [message #1007166 is a reply to message #1007160] |
Mon, 04 February 2013 11:27  |
Thanks, Ed! It works... but it is really ugly, so dont do this at home!
Ed Merks wrote on Mon, 04 February 2013 17:10You'd need to specialize copyReference. Essentially copying the whole
copy.
FUDForum. Page generated in 0.06126 seconds
