Multiple diagrams and generated xxxDocumentProvider synchronization code [message #100499] |
Fri, 02 February 2007 07:51  |
Originally posted by: thomas.forster.iese.fhg.de
Hi all,
my data model has recursive structures and on certain elements I can
open sub diagrams so I can continue modelling there.
However I came across a problem: Whenever I create and open a new sub
diagram on an element, the DocumentProviders handleResourcesChanged
method gets called (to synchronize the resources in the resource set, I
guess)
A side effect of this call is that all resources in the ResourceSet (I
have only one, because I use the extension point
org.eclipse.emf.transaction.editingDomains) that have to do with my
diagrams business model and notation model get unloaded and reloaded
again. The reload creates a completely new model instance. Any
references to the former model instance are of no value because the
actual model instance of the editor has changed. (Moreover all adapters
get removed from the model).
As a workaround I excluded the domain model resource from the reload in
the DocumentProviders handleResourceChange - Method. So far this seems
to work.
Does anybody know what the side effects might be? Is there a reason why
all resources are reloaded on a resource change?
Regards Thomas
Re: Multiple diagrams and generated xxxDocumentProvider synchronization code [message #100710 is a reply to message #100558] |
Fri, 02 February 2007 11:15  |
Alex Shatalin schrieb:
> Hello Thomas,
>> why
> Sure. It was done to load changes made on another diagram in a separate
> EditingDomain. Cince you are using shared editing domain for both
> diagrams, reloading process is not so important for you but if somebody
> changes model resource in EMf editor you will never get these changes
> propagated to your diagram until editor reopening.
> Alex Shatalin
Hello Alex,
thanks for your reply, I don't plan to use separate EditingDomains, so
the approach will work for me.
Thomas
FUDForum. Page generated in 0.23728 seconds
