Home » Eclipse Projects » Rich Client Platform (RCP) » E4 RCP Part createContents gets executed multiple times(E4 RCP Part createContents gets executed multiple times)
E4 RCP Part createContents gets executed multiple times [message #1006853] Sat, 02 February 2013 17:37 Go to next message
I run into a very strange problem with UI creation/injection in RCP 2.0
Basically I have a part with flag Multiple=true with a method responsible for creating its UI annotated with @Inject like this:
@Inject
public void createControls(Composite parent, @Named(IServiceConstants.ACTIVE_SHELL) final Shell shell) {
		//Create the UI
Part represents a detail view of some item selected from a treeView; here is how I create/show the part in doubleclick handler of the treeviewer:
List<String> tags = new ArrayList<String>();
tags.add("SAMPLE" + node.getId());
List<MPart> found = modelService.findElements(application, null, MPart.class, tags);
	if (found != null && !found.isEmpty()) {
		partService.showPart(found.get(0), PartState.VISIBLE);
		((SampleDetailPart) found.get(0).getObject()).setSample(node.getId());
	} else {
                MPart newPart = partService.createPart(SampleDetailPart.PART_ID);
		newPart.getTags().add("SAMPLE" + node.getId());
		partService.showPart(newPart, PartState.VISIBLE);
		newPart.setLabel(node.getName());//Set the model data for the part
		((SampleDetailPart) newPart.getObject()).setSample(node.getId());
For some reason, the createContents method get executed multiple times, everytime the part is moved or has regaind focus, creating duplicate UI as can be seen in the picture below
Part after being created:
index.php/fa/13272/0/
Part after switching to another part in the same stack and back - createContents has been called twice
index.php/fa/13273/0/
Did I miss something obvious? Any advice would be most appreciated.
Thanks a lot
cheers
matus
  • Attachment: correct.png
    (Size: 11.68KB, Downloaded 1222 times)
  • Attachment: wrong.png
    (Size: 13.98KB, Downloaded 1171 times)
Re: E4 RCP Part createContents gets executed multiple times [message #1006958 is a reply to message #1006853] Sun, 03 February 2013 03:36 Go to previous messageGo to next message
Better asked at e4-newsgroup, but anyways: You should not use @Inject
but @PostConstruct for the creation of the UI. @Inject methods will be
called everytime a value changes.
Tom
Am 02.02.13 23:38, schrieb matus majchrak:
> @Inject
> //Create the UI
> } else {
> Thanks a lot
> cheers
> matus
Re: E4 RCP Part createContents gets executed multiple times [message #1006978 is a reply to message #1006958] Sun, 03 February 2013 08:45 Go to previous messageGo to next message
Hi and thanks for the quick response.
The problem is, I had my methods annotated with @PostConstruct, but than they would not be executed at all. When I debug this I could see, that constructors got invoked, but not the createContents method. I actually managed to reproduce it with this sample:
Just add a Part to e4xmi manifest with the following code - the result is I can see the part, but it has not UI contents.
public class BasicNavigatorPart {
	private static final Logger log = Logger.getLogger(BasicNavigatorPart.class);
	public BasicNavigatorPart(){
		log.info("** Constructor "+BasicNavigatorPart.class.getSimpleName());
	@PostConstruct
	public void createControls(Composite parent) {
		log.info("** creating UI "+BasicNavigatorPart.class.getSimpleName());
The constructor is invoked, but not the @postConstruct annotated method.
Any pointers?
Re: E4 RCP Part createContents gets executed multiple times [message #1006979 is a reply to message #1006978] Sun, 03 February 2013 09:02 Go to previous message
OK I found the solution, seems to be related to this bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=348123
Changing javax.annotation to 1.0.0 fixed the issues, and now the method with @postConstructs get invoked the way it should.
Thanks again for your help.
cheers
matus
Previous Topic:Get the Command id in a PropertyTester
Next Topic:How enable and disable buttons using event in SWT.
Current Time: Sat Jul 26 18:54:46 EDT 2025
Powered by FUDForum. Page generated in 0.03569 seconds
