Home » Newcomers » Newcomers » IDE cvs does not recognize custom tags/branches automatically
IDE cvs does not recognize custom tags/branches automatically [message #100695] Fri, 09 September 2005 05:14 Go to next message
Originally posted by: tonimenzel.gmx.de
Hi there!
We have a fairly static cvs-structure with tagged versions on file-basis.
These tags (modulversions) were not recognized by eclipse's "select
branch/tag" panel..
As I noticed in the helpsystem, we can add _each_ tags for each module
manually. This is not an isse if those taggs would be static and do not
grow (in count). But they do, obviously:-(
Therefor we try to write those "available tags" in the .project file
which should be checked automatically if a get it right.
But the problem is: what is the concrete syntax of that
projectDescription? If there a dscription/dtd somewhere?
Is there another approach?
Until now our company uses netbeans 3.5/6 - and there you just set the
branch/tag-name on any file/directory directly.
Too bad;-(
I - as a pure eclipse devotee privatly - want that stuff in the company;-)
thanks in advance,
Toni
Re: IDE cvs does not recognize custom tags/branches automatically [message #100728 is a reply to message #100695] Fri, 09 September 2005 06:52 Go to previous message
Originally posted by: daniel.megert.gmx.net
Toni Menzel wrote:
> Hi there!
> branch/tag" panel..
> not grow (in count). But they do, obviously:-(
If you use 3.1 you can auto-refresh those tags: Preference > Team >
CVSRefresh tags when comparing or replacing tags
Dani
> Too bad;-(
> company;-)
> thanks in advance,
> Toni
Previous Topic:jardesc from ant in eclipse
Next Topic:Eclipse update site mirrors
Current Time: Fri Jul 18 17:46:43 EDT 2025
Powered by FUDForum. Page generated in 0.10688 seconds
