Home » Modeling » EMF » [CDO][Teneo] How to write / read LOB data stream based?
[CDO][Teneo] How to write / read LOB data stream based? [message #1006820] |
Sat, 02 February 2013 07:02  |
I am currently struggling with the problem that I do not know how to
write / read a LOB typed attribute of an Ecore model into the DB as
stream (to prevent OutOfMemory errors - want to save files in the db).
I defined the Ecore model like described in the Teneo Wiki:
http://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Teneo_Annotation_Examples
--> Lob Annotation
Furthermore the wiki tells how to create a java.sql.Blob with a
Hibernate method which doesn't seem to be available any more.
Blob blob = Hibernate.createBlob(new byte[] { 1, 2, 3, 4 });
It seems that a Hibernate Session is needed for creating a Blob:
LobHelper myLobHelper = org.hibernate.Session.getLobHelper
Blob myBlob = myLobHelper.createBlob(InputStream stream,
long length)
Is there a way to get the underlying hibernate session to accomplish this?
Is this the correct approach anyhow to to write / read LOBs stream-based
to/from the DB?
Thanks!
Kris
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006826 is a reply to message #1006822] |
Sat, 02 February 2013 09:10   |
Hello Eike,
thanks! At first sight of LobTest I thought it is CDO DB Store specific
and I have to search for another solution when using hibernate store.
Apparently, it is not.
Is there any further info on how to load the etypes.ecore into the
model, as mentioned in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=284307 -> Comment 16?
Kris
Am 02.02.13 13:30, schrieb Eike Stepper:
> Am 02.02.2013 13:02, schrieb KW:
>> Hi,
>> --> Lob Annotation
>> long length)
>> this?
>> stream-based to/from the DB?
> Why do you mention the DB? Are you trying to do things on the server side?
> Normally you would just interface the model API on the client side. Some
> usage examples are in LobTest:
> http://git.eclipse.org/c/cdo/cdo.git/tree/plugins/org.eclipse.emf.cdo.tests/src/org/eclipse/emf/cdo/tests/LobTest.java
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006829 is a reply to message #1006826] |
Sat, 02 February 2013 09:32   |
Should work like described here:
http://stackoverflow.com/questions/9384813/can-i-reuse-ecore-models-by-importing-them-into-other-models
In the Load Resource Pop-Up I chose "Browse Registered Packages" and
then "http://www.eclipse.org/emf/CDO/Etypes/4.0.0" and let the default
option "Development Time Version" instead of "Runtime Version".
Is the "Development Time Version" option correct?
Kris
Am 02.02.13 15:10, schrieb KW:
> Hello Eike,
> Thanks
> Kris
>>> Hi,
>>> --> Lob Annotation
>>> long length)
>>> this?
>> side?
>> Cheers
>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006840 is a reply to message #1006829] |
Sat, 02 February 2013 13:38   |
I was able to use the Blob type from the etypes in my model, regenerated
everything with a clean db, and when the first commit is called,
following error on server side:
[ERROR] Rollback in HibernateStore:
org.eclipse.emf.teneo.annotations.parser.AnnotationParserException: The
eclass: HbAnnotatedEPackage does not have an efeature for Lob
at
org.eclipse.emf.teneo.annotations.parser.EAnnotationParserImporter.processAnnotatedModelElement(EAnnotationParserImporter.java:149)
at
org.eclipse.emf.teneo.annotations.parser.EAnnotationParserImporter.process(EAnnotationParserImporter.java:65)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBuilder.buildMapping(PersistenceMappingBuilder.java:171)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBuilder.buildMapping(PersistenceMappingBuilder.java:88)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBuilder.buildMapping(PersistenceMappingBuilder.java:80)
at
org.eclipse.emf.teneo.hibernate.mapper.MappingUtil.generateMapping(MappingUtil.java:81)
at
org.eclipse.emf.cdo.server.hibernate.teneo.CDOMappingGenerator.generateMapping(CDOMappingGenerator.java:117)
at
org.eclipse.emf.cdo.server.hibernate.internal.teneo.TeneoHibernateMappingProvider.generateMapping(TeneoHibernateMappingProvider.java:146)
at
org.eclipse.emf.cdo.server.hibernate.internal.teneo.TeneoHibernateMappingProvider.getMapping(TeneoHibernateMappingProvider.java:76)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore.initConfiguration(HibernateStore.java:520)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore.getHibernateSessionFactory(HibernateStore.java:256)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.beginHibernateSession(HibernateStoreAccessor.java:194)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.getNewHibernateSession(HibernateStoreAccessor.java:291)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(HibernateStoreAccessor.java:661)
at
org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:149)
at
org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:487)
at
org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:43)
at
org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
at
org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:262)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:96)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:86)
at
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:680)
Any idea what could be the problem?
Kris
Am 02.02.13 15:32, schrieb KW:
> Thanks
> Kris
>> Hello Eike,
>> Thanks
>> Kris
>>>> Hi,
>>>> --> Lob Annotation
>>>> long length)
>>>> this?
>>> side?
>>> Cheers
>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006867 is a reply to message #1006840] |
Sun, 03 February 2013 00:15   |
Am 02.02.2013 19:38, schrieb KW:
> I was able to use the Blob type from the etypes in my model, regenerated everything with a clean db, and when the
> first commit is called, following error on server side:
> [ERROR] Rollback in HibernateStore: org.eclipse.emf.teneo.annotations.parser.AnnotationParserException: The eclass:
To me this looks like a problem in Teneo. Martin?
Cheers
/Eike
> at
> at org.eclipse.emf.teneo.annotations.parser.EAnnotationParserImporter.process(EAnnotationParserImporter.java:65)
> at org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBuilder.buildMapping(PersistenceMappingBuilder.java:171)
> at org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBuilder.buildMapping(PersistenceMappingBuilder.java:88)
> at org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBuilder.buildMapping(PersistenceMappingBuilder.java:80)
> at org.eclipse.emf.teneo.hibernate.mapper.MappingUtil.generateMapping(MappingUtil.java:81)
> at org.eclipse.emf.cdo.server.hibernate.teneo.CDOMappingGenerator.generateMapping(CDOMappingGenerator.java:117)
> at
> at
> at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore.initConfiguration(HibernateStore.java:520)
> at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore.getHibernateSessionFactory(HibernateStore.java:256)
> at
> at
> at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(HibernateStoreAccessor.java:661)
> at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:149)
> at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:487)
> at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:43)
> at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
> at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
> at
> at
> at
> at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:86)
> at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
> at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
> at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006869 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006873 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006877 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006881 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006885 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006889 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006893 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006897 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006901 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006905 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006909 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006913 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006917 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006921 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006925 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006929 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006933 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006937 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006941 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006945 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006949 is a reply to message #1006840] |
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006977 is a reply to message #1006867] |
Sun, 03 February 2013 08:27   |
Hi Kris,
It seems that the Lob annotation is on the EPackage, it should be on the efeature storing the lob. But... for CDO/Teneo
you don't need to set the @Lob annotation. You don't need to use the Hibernate Lob either.
To work with blob/clob you should use the CDO Blob/CLOb types from the CDO ETypes epackage. Teneo will automatically
take care of mapping them as lobs.
gr. Martin
> Cheers
> /Eike
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks
>> Kris
>>> Thanks
>>> Kris
>>>> Hello Eike,
>>>> Thanks
>>>> Kris
>>>>>> Hi,
>>>>>> --> Lob Annotation
>>>>>> long length)
>>>>>> this?
>>>>> side?
>>>>> Cheers
>>>>> /Eike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1007191 is a reply to message #1006977] |
Mon, 04 February 2013 16:27  |
Hooray - it works now!
I don't know why the annation went up to package level - I assume it
happened accidentaly when I was referencin the cdo etypes types via
"Load Resource".
Thank you Eike / Ed / Martin!
Am 03.02.13 14:27, schrieb Martin Taal:
> Hi Kris,
> efeature storing the lob. But... for CDO/Teneo you don't need to set the
> CDO ETypes epackage. Teneo will automatically take care of mapping them
> as lobs.
> gr. Martin
>>> The eclass:
>> Cheers
>> /Eike
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks
>>> Kris
>>>> Thanks
>>>> Kris
>>>>> Hello Eike,
>>>>> specific
>>>>> Thanks
>>>>> Kris
>>>>>>> Hi,
>>>>>>> db).
>>>>>>> --> Lob Annotation
>>>>>>> long length)
>>>>>>> this?
>>>>>> side?
>>>>>> side. Some
>>>>>> Cheers
>>>>>> /Eike
Current Time: Wed Jul 23 04:02:49 EDT 2025
Powered by FUDForum. Page generated in 0.84124 seconds
