Home » Modeling » TMF (Xtext) » How to turn an expression String into an Xtext object?
How to turn an expression String into an Xtext object? [message #785840] Sun, 29 January 2012 10:34 Go to next message
I have a DSL and a Debugger with Xtext 2.1.1 under Eclipse 3.7. Now I want to add an "Expressions View". When the expression view calls MyDslWatchExpressionDelegate.evaluateExpression(), the expression is passed as a String. So my question is, how can I turn this String into an Xtext object to which the MyDsl document is linked somehow, so that the expression can be evaluated considering references to the document. (I have a calculator like that from the Xtext arithmetics example in place.)
For example, if we had in a .mydsl document (don't care for the actual language) something like
int a = 3
int b = 4
the user might enter "a + b" in the expression view, and MyDslWatchExpressionDelegate.evaluateExpression() will be called with "a + b". How can I turn "a + b" into an object that can be passed to the calculator's evaluate function?
I could parse the string as a new document, but I don't know how to link the original document to the new one so that a and b could be referenced correctly.
Many thanks in advance for any kind of hint.
Uli
Re: How to turn an expression String into an Xtext object? [message #1006816 is a reply to message #785840] Sat, 02 February 2013 06:37 Go to previous messageGo to next message
It's been a year now and no answer to your request... Unfortunately, I do not have one myself, but it happens that I would like exactly what you were looking for. Did you receive any suggestion ? Implement this by yourself ? In any case, I would be interested by the solution you have chosen.
Thanks !
Re: How to turn an expression String into an Xtext object? [message #1006819 is a reply to message #1006816] Sat, 02 February 2013 07:00 Go to previous message
am not quite sure what you want to do (standalone, in eclipse ...),
but you can obtain a project aware resourceset using org.eclipse.xtext.ui.resource.IResourceSetProvider.
and you can load a resource from a string using org.eclipse.emf.ecore.resource.Resource.load(InputStream, Map<?, ?>)
[Updated on: Sat, 02 February 2013 07:04] by Moderator
Previous Topic:writing to IXtextDocument
Next Topic:DSL showing attributes based on its content value
Current Time: Sun Jul 27 03:26:14 EDT 2025
Powered by FUDForum. Page generated in 0.58283 seconds
