Home » Language IDEs » C / C++ IDE (CDT) » How can the declaration of an unused variable affect behavior?(question about variable declaration in c)
How can the declaration of an unused variable affect behavior? [message #1006792] Fri, 01 February 2013 17:55 Go to next message
I am using eclipse juno with gcc (from xcode) on MacOS.
The behaviour of the following C program changes radically when the declaration
int x;
is omitted. The variable x does not appear anywhere else in the code. How can this happen?
Here, data.txt is a simple text file with two digit numbers stored as characters. Something like 08 90 88 77 34 etc...
With the declaration of x included, the program opens a file, displays the first two numbers (as integers) and closed the file. Without the declaration, the program opens the file and displays the first number. It doesn't properly close the file.
How can this be?
#include <stdio.h>
int main (void)
FILE *fp;
// if I remove this declaration, the program does not work properly!!!
// this variable is not even used in the program
int x;
char str[2];
fp = fopen("data.txt", "r");
if (fp == NULL){
printf("\n unsuccessfull file open \n");
return 1;
}else{
printf("\n successfull file open \n");
fscanf(fp,"%2s",str);
printf("%s ",str);
printf("%s ",str);
if (fclose(fp)) {
printf("\n unsuccessfull file close \n");
}else{
printf("\n successfull file close \n");
return 0;
Re: How can the declaration of an unused variable affect behavior? [message #1006797 is a reply to message #1006792] Fri, 01 February 2013 20:05 Go to previous messageGo to next message
> declaration
> int x;
> How can this be?
> #include <stdio.h>
> int main (void)
> FILE *fp;
> int x;
> char str[2];
> if (fp == NULL){
> return 1;
> }else{
> printf("%s ",str);
> printf("%s ",str);
> if (fclose(fp)) {
> }else{
> return 0;
Strings get terminated with a null character. Your array is only 2
bytes long.
Re: How can the declaration of an unused variable affect behavior? [message #1006798 is a reply to message #1006797] Fri, 01 February 2013 21:39 Go to previous messageGo to next message
David,
Thank you so much for your quick, clear and correct answer. I really appreciate it.
While I'm at it, let me just ask you to clarify something for me:
I was accessing memory beyond the reserved array space. That's the reason that it resulted in wacky (and probably unpredictable) results.
Is that right?
What really threw me when I was trying to debug this was that the error seemingly disappeared when I declared a variable at that spot. I guess I was causing the compiler to make some room just after the space allocated to the array, thus hiding the mistake.
Is that right? (or at least possible)
WOW. What an insidious bug!
dan
Re: How can the declaration of an unused variable affect behavior? [message #1006808 is a reply to message #1006798] Sat, 02 February 2013 00:40 Go to previous message
Yes, this is what was happening.
Note that your question really wasn't an Eclipse CDT question, it was a
basic programming question. That really isn't the purpose for these
forums. This forum is for questions specifically relating to using the CDT
Previous Topic:How do I stop Builder Settings adding a -k to the Makefile command
Next Topic:Issues on Eclipse Semantic Checker
Current Time: Sat Jul 26 10:15:30 EDT 2025
Powered by FUDForum. Page generated in 0.05074 seconds
