Home » Language IDEs » Java Development Tools (JDT) » What is the role of I*Binding in Eclipse JDT?
What is the role of I*Binding in Eclipse JDT? [message #1006156] Wed, 30 January 2013 04:30 Go to next message
Hi all,
My current understanding is that JDT provides us two different interface and class hierachies for representing and manipulating Java code:
Java Model: provides a way of representing a java project. Fast to create but does not contain as many information as AST class hierachy, for example there are no information available about the exact position of each element in the source file (in AST that's available)
AST: more detailed representation of the source code plus provides means for manipulating it.
Is that correct?
Now, there is also a hierarchy of interfaces named I*Binding (starting at IBinding), for example IMethodBinding. So for example, we have 3 different types for dealing with methods:
IMethod (from Java Model) - http://help.eclipse.org/indigo/index.jsp?topic=/org.eclipse.jdt.doc.isv/reference/api/org/eclipse/jdt/core/IMethod.html
MethodInvocation (from AST, could get it from IMethod) - http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse.jdt.doc.isv/reference/api/org/eclipse/jdt/core/dom/MethodInvocation.html
IMethodBinding - http://help.eclipse.org/indigo/topic/org.eclipse.jdt.doc.isv/reference/api/org/eclipse/jdt/core/dom/IMethodBinding.html
From doc IMethodBinding seems very like MethodInvocation from AST but I don't see a clear distinction and when should I use them. Could someone please clarify this?
Cheers!
Re: What is the role of I*Binding in Eclipse JDT? [message #1006776 is a reply to message #1006156] Fri, 01 February 2013 13:54 Go to previous message
To see the difference you may, e.g., look at the return type of a method:
- Java Model: String IMethod.getReturnType()
- AST: Type MethodDeclaration.getReturnType2()
- Binding: ITypeBinding IMethodBinding.getReturnType()
The first is just a String, the name of the return type. In the AST you get the same information but artfully wrapped in syntax nodes like SimpleType(SimpleName).
Only in the binding will you find the resolved type, an object which you can query for the various properties of this type. OTOH, resolving is an expensive operation, hence the other kinds, which can be constructed more easily.
HTH,
Stephan
Previous Topic:Eclipse Plugin Development - Editor
Next Topic:suppress null analysis for anonymous classes (using guava)
Current Time: Sun Jul 27 00:34:51 EDT 2025
Powered by FUDForum. Page generated in 0.03420 seconds
