[Texo] HTTP Basic Authentification failed in JSONEObjectStore [message #1006503] |
Thu, 31 January 2013 09:19  |
currently i´am evalutating Texo for a RCP Client/Server Project.
I use it in a three tier architecture:
RCP Client / Tomcat Server / SQL Database
Now i want to add some enterprise features like authentification.
I configure Tomcat for basic authentifiction and override the beforeConnect Methode in JSONEObjectStore:
protected void beforeConnect(HttpURLConnection conn){
String userpass= "aUsername:aPassword";
conn.setRequestProperty("Authorization", "Basic "+Base64.encode(userpass.getBytes()));
I register the extended class at application start:
ComponentProvider.getInstance().register(JSONEObjectStore.class,JSONEObjectStoreWithAuthentication.class);
When the RCP Client connect to the Tomcat Server and the beforeConnect method is called then i got an exception:
java.lang.IllegalStateException: Already connected
at sun.net.www.protocol.http.HttpURLConnection.setRequestProperty(Unknown Source)
at de.texo.json.enhancements.JSONEObjectStoreWithAuthentication.beforeConnect(JSONEObjectStoreWithAuthentication.java:20)
at org.eclipse.emf.texo.json.JSONEObjectStore.doHTTPRequest(JSONEObjectStore.java:93)
at org.eclipse.emf.texo.json.JSONEObjectStore.doRequest(JSONEObjectStore.java:243)
at org.eclipse.emf.texo.json.JSONEObjectStore.query(JSONEObjectStore.java:281)
at org.eclipse.emf.texo.store.TexoResource.query(TexoResource.java:203)
I debugged the code and i think i found the reason is how the doHTTPRequest method of the JSONEObjectStore is implemented.
protected String doHTTPRequest(String urlStr, String method, String content) throws Exception {
String localUrlStr = urlStr == null ? getUri().toString() : urlStr;
final URL url = new URL(adaptUrl(localUrlStr));
final HttpURLConnection conn = (HttpURLConnection) url.openConnection();
conn.setRequestMethod(method);
conn.setDoInput(true);
conn.setDoOutput(true);
conn.setUseCaches(false);
conn.setRequestProperty("Accept-Charset", UTF8);
if (content != null) {
final byte[] bytes = content.getBytes(UTF8);
conn.setRequestProperty("Content-Type", JSONWebServiceObjectResolver.JSON_CONTENT_TYPE);
conn.setRequestProperty("Content-Length", String.valueOf(bytes.length));
[b]final OutputStream os = conn.getOutputStream();[/b]
os.write(bytes);
os.flush();
os.close();
[b] beforeConnect(conn);[/b]
final BufferedReader rd = new BufferedReader(new InputStreamReader(conn.getInputStream(), "UTF-8"));
final StringBuilder sb = new StringBuilder();
String line;
while ((line = rd.readLine()) != null) {
sb.append(line + "\n");
rd.close();
return sb.toString();
beforeConnect(conn) is a called in line 93.
At this point when beforeConnect is called the connection is already connected to ithe server by
final OutputStream os = conn.getOutputStream(); at line 87.
Is there a reason why beforeConnect(conn) is called at that late stage or could it be called at line 81, right after setting the other connection stuff?
Re: [Texo] HTTP Basic Authentification failed in JSONEObjectStore [message #1006506 is a reply to message #1006503] |
Thu, 31 January 2013 09:22   |
Hi Peter,
No specific reason and what you propose makes sense. Will change it and publish a new build.
gr. Martin
On 01/31/2013 03:19 PM, peter meyer wrote:
> @Override
> String userpass= "aUsername:aPassword"; conn.setRequestProperty("Authorization", "Basic
> at
> os.write(bytes);
> os.flush();
> os.close();
> String line;
> rd.close();
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] HTTP Basic Authentification failed in JSONEObjectStore [message #1006522 is a reply to message #1006503] |
Thu, 31 January 2013 09:56   |
Hi Peter,
I published a new build which changes this. Let me know if it works (or not...).
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399625
gr. Martin
> @Override
> at
> os.write(bytes);
> os.flush();
> os.close();
> String line;
> rd.close();
The Netherlands
FUDForum. Page generated in 0.48485 seconds
