Zoom Capability [message #1006583] |
Thu, 31 January 2013 17:38  |
Hi ,
I'm trying to implement Zoom capability in birt using Chart API. I went through the questions
posted regarding this in the forum. I also referred to the example posted in forum on chart
zooming using script.
So far,I have set the action type as ActionType.CALL_BACK_LITERAL and trying to implement the callback method.
I'm quite lost on how to get the Y-Axis label value when I click on it. It would be great if you could point me to some example. I'm also not quite sure how to implement showeventData() using chart API.
Kindly help me out.
Savitha.
Re: Zoom Capability [message #1008073 is a reply to message #1007845] |
Fri, 08 February 2013 13:10  |
It's just passed through the function in the invoke script area of the axis interactivity. If you open up the report in the designer, you can double click on the chart, go to the format chart tab, go to the y-axis section, then to the interactivity button, and you should see the interactivity that is set up.
FUDForum. Page generated in 0.08108 seconds
