Home » Modeling » Papyrus » Adding constraints to UML Profiles in Papyrus(How to validate UML Profiles in Papyrus)
Adding constraints to UML Profiles in Papyrus [message #997587] Tue, 08 January 2013 08:38 Go to next message
Recently, I've developed my own UML Profile using Papyrus.
Now my doubt is how can I add/associate OCL constraints to it?
My goal is to validate if a model that applies my profile is correct or not.
I'm using the following version of Eclipse:
Eclipse Modeling Tools
Version: Juno Service Release 1
Build id: 20120920-0800
Thanks in advance,
André Ribeiro
IST Lisbon
Portugal
Re: Adding constraints to UML Profiles in Papyrus [message #997589 is a reply to message #997587] Tue, 08 January 2013 08:56 Go to previous messageGo to next message
Hello André,
This feature is not supported in the current version of Papyrus. It should be supported in 0.10 (June 2013, Eclipse Kepler)
Camille
Re: Adding constraints to UML Profiles in Papyrus [message #997688 is a reply to message #997589] Tue, 08 January 2013 09:55 Go to previous messageGo to next message
Thanks for the answer Camille.
Is there any other way I can perform this validation?
Thank you once again.
Re: Adding constraints to UML Profiles in Papyrus [message #997689 is a reply to message #997688] Tue, 08 January 2013 09:57 Go to previous messageGo to next message
I guess you can implement your constraints in a new EMF Validation plug-in. Papyrus relies on this mechanism for validating the models.
Camille
Re: Adding constraints to UML Profiles in Papyrus [message #997697 is a reply to message #997689] Tue, 08 January 2013 10:10 Go to previous messageGo to next message
Just in case you need it - a tutorial is in the EMFV help:
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse.emf.validation.doc/references/examples/oclValidationExample.html
(The link is from galileo - you should find it in the local help of your installation).
The feature shipping with Juno is:
EMF Validation Framework SDK 1.6.0.v20120328-0001-67T-96SGR75UNqZNTdeQnghI6uFA org.eclipse.emf.validation.sdk.feature.group Eclipse Modeling Project
(You get it if you install the Modelling package)
HTH
Vlad
Re: Adding constraints to UML Profiles in Papyrus [message #997725 is a reply to message #997697] Tue, 08 January 2013 11:03 Go to previous messageGo to next message
Ok, I will explore that option.
Many thanks Camille and Vlad.
Re: Adding constraints to UML Profiles in Papyrus [message #997749 is a reply to message #997725] Tue, 08 January 2013 11:58 Go to previous messageGo to next message
The EMFv OCL tutorial is seriously old; a patch was supplied for Juno
but never applied. https://bugs.eclipse.org/bugs/show_bug.cgi?id=327956
You won't get very far trying to get profile constraints to execute
since EMFv ignores stereotype applications.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=397508
since there is no ConstraintProvider for UML Profiles.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=397519
These are problems I have fixed in the last week. You may find that
things are much better with the Kepler M5 release (3 Feb) of MDT/OCL
which can be installed on Juno.
Ed Willink
Re: Adding constraints to UML Profiles in Papyrus [message #997796 is a reply to message #997749] Tue, 08 January 2013 13:57 Go to previous messageGo to next message
Hi Ed,
So you suggest that the best option for me right now is to wait for the Kepler M5 release (3 Feb) of MDT/OCL?
Thanks for the reply.
Re: Adding constraints to UML Profiles in Papyrus [message #997837 is a reply to message #997749] Tue, 08 January 2013 16:06 Go to previous messageGo to next message
Hello everyone,
I have some additional comments.
1. I have used EMFv exactly as described in those tutorials and it worked with eclipse 3.7.2. So I think it's worth giving it a shot on 3.8 / 4.2.
2. I think EMFv, as it is, does have some advantages over alternate methods described in https://bugs.eclipse.org/bugs/show_bug.cgi?id=327956 .
* Constraints can be given IDs, can be grouped, documented and made visible for the user in the Properties pages.
* The oclinecore editor does not support any ecore model - so for the unsupported model the user has to edit the annotations with the sample ecore editor - which is cumbersome.
(e.g. eKeys are not supported - Is this still true ?)
* EMFv has support for live validation
3. @Andre: What exactly the constraints must constrain ? Do you have to access meta-properties defined by the stereotypes ?
If you only need standard meta-properties to express constraints, then EMFv should work.
Re: Adding constraints to UML Profiles in Papyrus [message #998024 is a reply to message #997837] Wed, 09 January 2013 03:01 Go to previous messageGo to next message
> 3.8 / 4.2.
In addition to the UMLProfileConstraintProvider, you may find the new
CompleteOCLConstraintProvider useful in M5. This makes the Complete OCL
constraints visible in the Preference pages.
There is a faint possibility that
http://wiki.eclipse.org/MDT/OCL/Debugger#The_Validations_View might
appear for Kepler.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=324924 was fixed for
Indigo (20 months ago).
Without a UMLTraversalStrategy, the stereotypeApplication will never be
self and so no Constraint attached to a Stereotype will be evaluated.
Ed Willink
Re: Adding constraints to UML Profiles in Papyrus [message #998666 is a reply to message #998024] Thu, 10 January 2013 08:16 Go to previous messageGo to next message
Answering to Vlad's question I will present an excerpt of my UML Profile metamodel:
index.php/fa/12933/0/
For instance, if the user defines a Class XisInteractionCompositeElement with compositeElementType == 'List', it can only be composed of XisActionElements with actionElementType == 'ListItem'.
Is it possible to define such a constraint?
Thanks.
Re: Adding constraints to UML Profiles in Papyrus [message #998690 is a reply to message #998666] Thu, 10 January 2013 09:08 Go to previous messageGo to next message
HI
I think you may have misunderstood 'Profile'; your example is not a
profile and has no user-defined stereotypes, so you are only using
ordinary constraints.
Ed Willink
On 10/01/2013 13:16, André Ribeiro wrote:
> Quote:
> Thanks.
Re: Adding constraints to UML Profiles in Papyrus [message #998711 is a reply to message #998690] Thu, 10 January 2013 09:42 Go to previous messageGo to next message
Hi Ed,
Probably I wasn't clear.
What I've presented above is the metamodel (where the UML metaclasses were omitted) and not a model that applies my Profile.
XisInteractionSpace, XisWidget, XisInteractionCompositeElement and so on, are indeed stereotypes that can be applied to classes.
XisOperation is a stereotype that can be applied to operations, while XisArgument can be applied to arguments of a XisOperation.
Re: Adding constraints to UML Profiles in Papyrus [message #999220 is a reply to message #998711] Fri, 11 January 2013 10:26 Go to previous messageGo to next message
Hi Andre,
This looks interesting.
1. What tool are you currently using ?
2. Can you provide a diagram showing the relationship between the stereotypes and UML meta-classes ?
3. Can you provide the source of the profile ?
Vlad
Re: Adding constraints to UML Profiles in Papyrus [message #999291 is a reply to message #999220] Fri, 11 January 2013 13:36 Go to previous messageGo to next message
Hi Vlad,
I'm using Papyrus, but I've used Enterprise Architect to model the previous excerpt of the profile.
Here is what I've done so far:
index.php/fa/12962/0/
Yes, I can provide you my Papyrus Project.
Can you please give some feedback about this?
Thank you!
  • Attachment: XisMobile.png
    (Size: 92.71KB, Downloaded 2745 times)
[Updated on: Mon, 14 January 2013 11:37] by Moderator
Re: Adding constraints to UML Profiles in Papyrus [message #1001964 is a reply to message #999291] Thu, 17 January 2013 11:10 Go to previous messageGo to next message
Hello!
Vlad, can you please answer my question?
Is it possible to validate a model that uses my profile?
Thank you!
Re: Adding constraints to UML Profiles in Papyrus [message #1002576 is a reply to message #1001964] Fri, 18 January 2013 16:43 Go to previous messageGo to next message
Hi Andre,
It is interesting that you are extending UML for this purpose.
I guess one major advantage is that you get a diagram editor with a small effort.
Well, as Camille stated here, Papyrus does not support this feature yet.
Also, as Ed said here, an EMFV-based solution would not work either at the moment.
Looking at your meta-model it seems like a quite heavy extenstion to UML.
You might consider defining your own stand-alone metamodel by using EMF/Ecore.
But in that would mean that you cannot use the Papyrus UML diagram editor for your models.
You could get a working editor for your language by using Graphiti.
But I haven't tried it myself.
You could find some ideas in the Eclipse DSL book (rather outdated).
Maybe somebody else has some better recommendations.
Best wishes
Vlad
Re: Adding constraints to UML Profiles in Papyrus [message #1006403 is a reply to message #997587] Thu, 31 January 2013 04:20 Go to previous messageGo to next message
Any guess on when this would be available?
Patrik
Re: Adding constraints to UML Profiles in Papyrus [message #1006521 is a reply to message #1006403] Thu, 31 January 2013 09:53 Go to previous messageGo to next message
It depends how close to the bleeding edge you like to be.
June: Kepler
End of next week: M5
Now: Latest Papyrus N-build, and MDT/OCL build from
https://hudson.eclipse.org/hudson/job/buckminster-mdt-ocl-branch-tests/
(might be an I-build tomorrow)
Realistically, I recommend that you wait for M5, and then report any
problems that you find so that may be fixed for M6.
OCL entry for profiles appears to work; see picture on my recent OCL
newsgroup posting.
Diagram validation using profile OCL is active work in progress; it
might be working but it probably isn't.
Ed Willink
> Regards
> Patrik
Re: Adding constraints to UML Profiles in Papyrus [message #1007843 is a reply to message #1006521] Thu, 07 February 2013 12:24 Go to previous messageGo to next message
Hi Ed,
Is it now possible (with the release of M5) to perform such a validation?
Thanks.
Re: Adding constraints to UML Profiles in Papyrus [message #1007998 is a reply to message #1007843] Thu, 07 February 2013 13:24 Go to previous message
To be honest I haven't tried recently; I've been working on a scoping
bug for direct use of base_xxx and extension_xxx at M1.
In principle, you just need to enable the Profile constraints in the
Window->Preferences->Model Validation window (they won't appear till
you've validated once) then Validate again.
Ed Willink
On 07/02/2013 17:25, André Ribeiro wrote:
> Hi Ed,
> Thanks.
Previous Topic:exporting sysML diagrams to Eclipse plugin
Next Topic:Centering description in use-case diagram
Current Time: Sat Jul 26 11:35:33 EDT 2025
Powered by FUDForum. Page generated in 0.09357 seconds
