Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] HTTP Basic Authentification failed in JSONEObjectStore
[Texo] HTTP Basic Authentification failed in JSONEObjectStore [message #1006503] Thu, 31 January 2013 09:19 Go to next message
currently i´am evalutating Texo for a RCP Client/Server Project.
I use it in a three tier architecture:
RCP Client / Tomcat Server / SQL Database
Now i want to add some enterprise features like authentification.
I configure Tomcat for basic authentifiction and override the beforeConnect Methode in JSONEObjectStore:
protected void beforeConnect(HttpURLConnection conn){
  String userpass= "aUsername:aPassword";
  conn.setRequestProperty("Authorization", "Basic "+Base64.encode(userpass.getBytes()));
I register the extended class at application start:
ComponentProvider.getInstance().register(JSONEObjectStore.class,JSONEObjectStoreWithAuthentication.class);
When the RCP Client connect to the Tomcat Server and the beforeConnect method is called then i got an exception:
java.lang.IllegalStateException: Already connected
	at sun.net.www.protocol.http.HttpURLConnection.setRequestProperty(Unknown Source)
	at de.texo.json.enhancements.JSONEObjectStoreWithAuthentication.beforeConnect(JSONEObjectStoreWithAuthentication.java:20)
	at org.eclipse.emf.texo.json.JSONEObjectStore.doHTTPRequest(JSONEObjectStore.java:93)
	at org.eclipse.emf.texo.json.JSONEObjectStore.doRequest(JSONEObjectStore.java:243)
	at org.eclipse.emf.texo.json.JSONEObjectStore.query(JSONEObjectStore.java:281)
	at org.eclipse.emf.texo.store.TexoResource.query(TexoResource.java:203)
I debugged the code and i think i found the reason is how the doHTTPRequest method of the JSONEObjectStore is implemented.
protected String doHTTPRequest(String urlStr, String method, String content) throws Exception {
    String localUrlStr = urlStr == null ? getUri().toString() : urlStr;
    final URL url = new URL(adaptUrl(localUrlStr));
    final HttpURLConnection conn = (HttpURLConnection) url.openConnection();
    conn.setRequestMethod(method);
    conn.setDoInput(true);
    conn.setDoOutput(true);
    conn.setUseCaches(false);
    conn.setRequestProperty("Accept-Charset", UTF8);
    if (content != null) {
      final byte[] bytes = content.getBytes(UTF8);
      conn.setRequestProperty("Content-Type", JSONWebServiceObjectResolver.JSON_CONTENT_TYPE);
      conn.setRequestProperty("Content-Length", String.valueOf(bytes.length));
      [b]final OutputStream os = conn.getOutputStream();[/b]
      os.write(bytes);
      os.flush();
      os.close();
  [b]  beforeConnect(conn);[/b]
    final BufferedReader rd = new BufferedReader(new InputStreamReader(conn.getInputStream(), "UTF-8"));
    final StringBuilder sb = new StringBuilder();
    String line;
    while ((line = rd.readLine()) != null) {
      sb.append(line + "\n");
    rd.close();
    return sb.toString();
beforeConnect(conn) is a called in line 93.
At this point when beforeConnect is called the connection is already connected to ithe server by
final OutputStream os = conn.getOutputStream(); at line 87.
Is there a reason why beforeConnect(conn) is called at that late stage or could it be called at line 81, right after setting the other connection stuff?
Re: [Texo] HTTP Basic Authentification failed in JSONEObjectStore [message #1006506 is a reply to message #1006503] Thu, 31 January 2013 09:22 Go to previous messageGo to next message
Hi Peter,
No specific reason and what you propose makes sense. Will change it and publish a new build.
gr. Martin
On 01/31/2013 03:19 PM, peter meyer wrote:
> @Override
> String userpass= "aUsername:aPassword"; conn.setRequestProperty("Authorization", "Basic
> at
> os.write(bytes);
> os.flush();
> os.close();
> String line;
> rd.close();
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] HTTP Basic Authentification failed in JSONEObjectStore [message #1006522 is a reply to message #1006503] Thu, 31 January 2013 09:56 Go to previous messageGo to next message
Hi Peter,
I published a new build which changes this. Let me know if it works (or not...).
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399625
gr. Martin
> @Override
> at
> os.write(bytes);
> os.flush();
> os.close();
> String line;
> rd.close();
The Netherlands
Re: [Texo] HTTP Basic Authentification failed in JSONEObjectStore [message #1006627 is a reply to message #1006522] Fri, 01 February 2013 04:22 Go to previous message
Hi Martin,
many thanks for your quick reply and the fix.
Now it works properly!
best regards
Peter
Previous Topic:EMFStore and EMFCompare integration
Next Topic:[Texo] Map is not a known entity type
Current Time: Wed Jul 23 11:41:58 EDT 2025
Powered by FUDForum. Page generated in 0.41935 seconds
