Home » Eclipse Projects » P2 » P2 update mechanism under Indigo(Failing to get P2 update examples working)
P2 update mechanism under Indigo [message #1006388] Thu, 31 January 2013 03:34 Go to next message
I tried to get the P2 update examples from the GIT repository rt.equinox.p2 working. Both examples projects
  • org.eclipse.equinox.p2.examples.rcp.sdknoautoupdates
  • org.eclipse.equinox.p2.examples.rcp.prestartupdate
seem to be not up to date.
In the first example I get the message
Could not locate the running profile instance. The eclipse.p2.data.area and eclipse.p2.profile properties may not be set correctly in this application's config.ini file.
The second one throws a NPE
	at org.eclipse.equinox.p2.operations.UpdateOperation.getInstalledIUs(UpdateOperation.java:295)
	at org.eclipse.equinox.p2.operations.UpdateOperation.prepareToResolve(UpdateOperation.java:280)
	at org.eclipse.equinox.p2.operations.ProfileChangeOperation.resolveModal(ProfileChangeOperation.java:112)
	at org.eclipse.equinox.p2.examples.rcp.prestartupdate.P2Util.checkForUpdates(P2Util.java:49)
	at org.eclipse.equinox.p2.examples.rcp.prestartupdate.ApplicationWorkbenchWindowAdvisor$1.run(ApplicationWorkbenchWindowAdvisor.java:76)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
	... 38 more
After fixing the example according to
http://www.eclipse.org/forums/index.php?t=msg&goto=554285&S=db68a0daf2c1bb0915daac6bd300c108 I get the same errors.
My question: is there any working example out of the box which could be run under Eclipse 3.7 or 3.8?
Thank you very much.
Michael
Re: P2 update mechanism under Indigo [message #1062649 is a reply to message #1006388] Mon, 10 June 2013 04:59 Go to previous message
if you find/found some, let me know!
Previous Topic:How to query a p2 for IUs by its provided capabilities?
Next Topic:Corrupted application after broken update
Current Time: Wed Jul 23 15:36:33 EDT 2025
Powered by FUDForum. Page generated in 0.03281 seconds
