Home » Modeling » TMF (Xtext) » References from other file not working(xtext scoping problem)
References from other file not working [message #1006177] Wed, 30 January 2013 06:02 Go to next message
I have a simple json grammer that has support for referencing to "named object" by using the "uses" attribute.
grammar com.example.Json with org.eclipse.xtext.common.Terminals
generate json "http://eclipse.org"
Object:
		(members+=Member)?
		(',' members+=Member)*
Member:
	GenericMember | NamedMember | UsesMember;
GenericMember:
	key=STRING ':' name=Value;
NamedMember:
	key='\"name\"' ':' name=STRING;
UsesMember:
	key='\"uses\"' ':' name=[NamedMember | STRING];
Value:
	Object | STRING | Array | Boolean | Null | Number;
Array:
	'[' (values+=Value)? (',' values+=Value)* ']';
Boolean:
  'true' | 'false';
Null:
  'null';
terminal Number:
	'-'? INT? '.' INT (('E'|'e') '-'? INT)?;
An example of the json:
	"obj1": {
		"name": "name1"
	"obj2": {
		"uses": "name1"
The content assistance only displays the named object of the current file.
From what I can tell from the video the cross file referencing should work out of the box.
I tried changing my workflow but without success:
                // scoping and exporting API
                fragment = scoping.ImportURIScopingFragment {}
                fragment = exporting.SimpleNamesFragment {}
                fragment = scoping.ImportNamespacesScopingFragment {}
                fragment = exporting.QualifiedNamesFragment {}
                fragment = builder.BuilderIntegrationFragment {}
I am a bit lost as to where I should start fixing this.
Most tutorials are about how to change the scoping behaviour but not on how to allow scoping cross file without any imports.
Re: References from other file not working [message #1006191 is a reply to message #1006177] Wed, 30 January 2013 07:06 Go to previous messageGo to next message
HI,
dont mix that fragments.
should be fine and enable global visbility.
Re: References from other file not working [message #1006297 is a reply to message #1006177] Wed, 30 January 2013 12:47 Go to previous messageGo to next message
I still have the same problem after I modified the workflow fragments.
Could this be related to the scope provider?
public class JsonScopeProvider extends AbstractDeclarativeScopeProvider {
Maybe there something wrong with my grammar.
It is difficult to know what xtext is "thinking" is there a way to know more about this during run-time.
Now I am just left with knowing it is not working but no real methodology to get to the hard of the problem.
Re: References from other file not working [message #1006313 is a reply to message #1006297] Wed, 30 January 2013 14:11 Go to previous message
(1) create a new project using the wizard
(2) paste the grammar and run the workflow
(3) launch runtime eclipse and create a new project
(4) create .mydsl files and have fun
Previous Topic:JvmModelInferrer refer to a java class not in the model
Next Topic:Retrieve info from EMF model in UI action and then use it to modify the model itself
Current Time: Sun Jul 27 03:59:30 EDT 2025
Powered by FUDForum. Page generated in 0.05465 seconds
