Home » Modeling » ATL » ATL File usging second ATL File and input variable of ATL File
ATL File usging second ATL File and input variable of ATL File [message #1006017] Tue, 29 January 2013 09:59 Go to next message
I have two differents problems which are :
- I have an ATL Plug-in with my "fileA.atl" and i want to create a second ATL file "fileB.atl" using all rules of the first file ("fileA.atl") with other rules defined in the second file ("fileB.atl"). Is that possible? How can do that ?
- I want to use a java variable (in fact, the input name file without extension) in my ATL file. Is that possible? How can do that?
Thanks in advance for your help.
Nicolas
Re: ATL File usging second ATL File and input variable of ATL File [message #1006066 is a reply to message #1006017] Tue, 29 January 2013 12:15 Go to previous messageGo to next message
First question: your problem looks like something that could be resolved using Module Superimposition in ATL.
Second question: no that's not possible. However, the common way to provide parameters to a transformation is to add another input model representing them (to do so, you can use the generic XML metamodel as provided by MoDisco for instance).
I hope this helps.
Hugo
Re: ATL File usging second ATL File and input variable of ATL File [message #1006145 is a reply to message #1006066] Wed, 30 January 2013 03:46 Go to previous messageGo to next message
Second question :
.eResource().getURI().toString()
on an element from the input model.
Re: ATL File usging second ATL File and input variable of ATL File [message #1006157 is a reply to message #1006066] Wed, 30 January 2013 04:30 Go to previous message
Thank you for your answer.
This one resolve my problem.
Nicolas
Previous Topic:using resolveTemp y the source patterns
Next Topic:In-place refining mode is now available for EMFTVM
Current Time: Wed Jul 23 06:13:54 EDT 2025
Powered by FUDForum. Page generated in 0.19761 seconds
