Home » Eclipse Projects » Eclipse 4 » Kepler's Java 8 status(Writing book on SE 8 / EE 7, need to know when Java 8 support will be available to end users)
icon5.gif  Kepler's Java 8 status [message #1004128] Tue, 22 January 2013 11:18 Go to next message
I recently signed a contract to write a book on Java SE 8 and Java EE 7 for release next December. The publisher's IDE of choice for its Java books is understandably Eclipse, due to its overwhelming popularity among software developers. However, I have discovered that with both Juno and the Kepler milestone (which I, of course, understand is not yet complete), I cannot select Java 1.8 as a language level (unlike a popular commercial IDE). As a result, even if I set up a custom builder to use the JDK 1.8 compiler, Eclipse highlights lambda expressions and default methods as syntax errors (not very useful for a reader learning Java 8 ).
I've seen the JDT Core/Java 8 page on the wiki (http://wiki.eclipse.org/JDT_Core/Java8) and gone over the associated bugs, but I'm not seeing any indication anywhere about how much of this will be available in Kepler. So, if possible, I'd like to find answers to the following questions:
1) Will Kepler (or at least a maintenance release of Kepler before December) allow users to select Java 1.8 as the language level and recognize lambda expressions as syntactically correct (most important)?
2) Will Kepler (or at least a maintenance release of Kepler before December) include a version of the JDT compiler that compiles in Java 8 (less important) or will users still need to define a custom builder?
Even a "probably" or "probably not" answer to these questions would be better than no answer at all. So, if anyone can shed some light on this, it would be greatly appreciated.
[Updated on: Tue, 22 January 2013 11:59] by Moderator
Re: Kepler's Java 8 status [message #1004230 is a reply to message #1004128] Tue, 22 January 2013 15:58 Go to previous messageGo to next message
I started a thread on this on jdt-dev mailing list!
Tom
Am 22.01.13 17:21, schrieb Nicholas Williams:
> Java 8).
> (less import) or will users still need to define a custom builder?
Re: Kepler's Java 8 status [message #1004333 is a reply to message #1004230] Tue, 22 January 2013 21:03 Go to previous messageGo to next message
Tom, you said you started a thread in the jdt-dev mailing list. I was not a member of that mailing list before, so I did not see the thread posted. The thread does not show up in the archive, but I don't know how long messages take to show up in there. I'm now a member, but I don't know if I may have missed any replies in the past several hours. Has there been any activity on the mailing list with regard to this issue?
Thomas Schindl wrote on Tue, 22 January 2013 15:58
Tom
Re: Kepler's Java 8 status [message #1004491 is a reply to message #1004333] Wed, 23 January 2013 05:45 Go to previous messageGo to next message
Sorry I pointed you to the wrong list :-( It was on jdt-core-dev
(https://dev.eclipse.org/mailman/listinfo/jdt-core-dev)
There you should see the conversation up until now.
Tom
Am 23.01.13 03:03, schrieb Nicholas Williams:
> Thanks
>> Tom
Re: Kepler's Java 8 status [message #1006080 is a reply to message #1004128] Tue, 29 January 2013 14:14 Go to previous messageGo to next message
What is the 'story' for Java EE 7 support in Kepler?
I am trying find out if Tomcat 8 will be a supported 'Server Runtime'.
vbk
Re: Kepler's Java 8 status [message #1006096 is a reply to message #1006080] Tue, 29 January 2013 16:12 Go to previous message
Ask at the wtp forum.
Tom
Am 29.01.13 20:14, schrieb vince kraemer:
> vbk
Previous Topic:What happened to CSSScratchpad?
Next Topic:Dynamic Help and Infopops
Current Time: Sun Jul 27 11:49:48 EDT 2025
Powered by FUDForum. Page generated in 0.04185 seconds
