Home » Modeling » EMF » How should I model this relationship.
How should I model this relationship. [message #1005931] Tue, 29 January 2013 05:40 Go to next message
Hey,
I am trying to create an EMF model for a legacy system as a PoC and I am
currently torn in how to model the relationship below.
Being a relative newbie in modelling, I need some advice and pointers.
The system I am trying to model is a provisioning orders subsystem.
The main object in this system is an Order.
Each order may have a reference to a "previous" order that establishes
order of execution of these Orders - the one that has a "previous"
reference would not be executed before the one it referes to..
So for example I would have following set of orders (where "<-" refers
to a previous order):
O1 <- O2 <- O3
O2 <- O4 <- O5
Another way of visualizing this relationship is by using a tree-like
representation:
O1 <- O2 <- O3
O4 <- O5
The reverese relationship is a lot like a containment relationshp, but
the orders are their own entities, so I can not really model them as
contained within other Orders.
On the other hand I need to be able to browse the reverse of "previous"
reference. I seem to remember an article describing this type of a
feature, but I can't find anything about it...
Re: How should I model this relationship. [message #1005954 is a reply to message #1005931] Tue, 29 January 2013 07:00 Go to previous messageGo to next message
Roland,
You could model it as a bidirectional non-containment reference like this:
package org.example.order
class Order
refers Order previous opposite next
refers Order[] next opposite previous
Of course this implies that adding a order will require saving the the
previous order to update the back reference; not sure if that's okay in
your design. The GenFeature for next can be configured to be displayed
as children in a tree view.
On 29/01/2013 11:40 AM, Roland Tepp wrote:
> Hey,
> am currently torn in how to model the relationship below.
> O1 <- O2 <- O3
> O2 <- O4 <- O5
> representation:
> O1 <- O2 <- O3
> O4 <- O5
> "previous" reference. I seem to remember an article describing this
> type of a feature, but I can't find anything about it...
Re: How should I model this relationship. [message #1008279 is a reply to message #1005954] Mon, 11 February 2013 07:47 Go to previous messageGo to next message
Hey Ed,
I would rather not do that as the backend storage (DB schema) of the
model is not very likely to change any time soon and I have very little
influence to change that.
I remember a discussion from a way back about using derived feature to
find all references pointing at the EObject, but I can't find this any
more...
As a more general question - what is the preferred solution to model
this type of references in EMF - specially considering that I might want
to be able change the actual Resource implementation depending on the
deployment scenario at some point in future?
29.01.2013 14:00, Ed Merks kirjutas:
> Roland,
> class Order
>> Hey,
>> O1 <- O2 <- O3
>> O2 <- O4 <- O5
>> representation:
>> O1 <- O2 <- O3
>> O4 <- O5
Re: How should I model this relationship. [message #1008343 is a reply to message #1008279] Tue, 12 February 2013 00:19 Go to previous messageGo to next message
Roland,
Comments below.
On 11/02/2013 1:47 PM, Roland Tepp wrote:
> Hey Ed,
> little influence to change that.
In terms of back end storage, it's not necessary that you persist both
ends of the reference. You could populate "next" from a database query.
> more...
Something like an ECrossReferenceAdapter can be used to manage inverse
relationships, but it relies on all objects of interest being in the
resource set.
> want to be able change the actual Resource implementation depending on
> the deployment scenario at some point in future?
Logically what you describe is modeled as I've shown. How that's
persisted to storage is another question but I don't know how you're
currently managing that. Certainly if everything is in a data base, the
problem is somewhat simpler because if the order of "next" doesn't
matter (you can mark it "unordered"), you can populate it from a query...
>> Roland,
>> this:
>> class Order
>>> Hey,
>>> O1 <- O2 <- O3
>>> O2 <- O4 <- O5
>>> representation:
>>> O1 <- O2 <- O3
>>> O4 <- O5
Re: How should I model this relationship. [message #1010913 is a reply to message #1008343] Mon, 18 February 2013 08:24 Go to previous messageGo to next message
Hi Ed,
Replies below.
12.02.2013 7:19, Ed Merks kirjutas:
> Roland,
> Comments below.
>> Hey Ed,
Yes, this is certainly a workable option.
However I would not want to be eagerly populating this list at load
time. Is there a way to have the whole list of "children" be proxied
without needing to know their ids up front.
(on the other hand, these clusters of related Order objects are fairly
small and well-contained, so this might not be as big of a overhead as I
am imagining it)
>> more...
> resource set.
Ah, that is somewhat undesireable - I really do not want to load the
entire world at startup...
yes, that is certainly a possibility.
Re: How should I model this relationship. [message #1011024 is a reply to message #1010913] Mon, 18 February 2013 12:25 Go to previous message
Roland,
Comments below.
On 18/02/2013 2:24 PM, Roland Tepp wrote:
> Hi Ed,
> Replies below.
>> Roland,
>> Comments below.
>>> Hey Ed,
>> query.
No, a list itself can't be a proxy.
> I am imagining it)
It always pays to measure first and worry later.
>>> more...
>> resource set.
Exactly.
>> query...
Previous Topic:Can i add ocl to ecore with java code?
Next Topic:[XCore] edit instances with XText editor
Current Time: Sun Jul 27 13:50:05 EDT 2025
Powered by FUDForum. Page generated in 0.04366 seconds
