Grid - onMouseExit hover question [message #997912] |
Tue, 08 January 2013 20:18  |
I had a quick question about the behavior of the hovering logic of the grid component.
So I've implemented my own GridHeaderRenderer which provides a more Win7 native look and feel. It looks great and works great (almost). My renderer supports 3 different states (mouseover/hover,mousedown/selected,normal). Most of the logic I need is already supported out of the box by extending DefaultColumnHeaderRenderer. The one issue I'm having is detecting then the column header is hovered and the mouse exits the Grid directly from the column header (by moving up).
I believe I've tracked the issue down to one particular piece of logic which I wanted to question here before I open a bug request to make sure my understanding is correct. In the onHoverCell the Grid initializes the hoveringColumnHeader to a valid column (along with other fields). While in the onMouseExist those same hover fields are reset, with the exception of hoveringColumnHeader. Then, when the following logic in the paintHeader method is executed:
column.getHeaderRenderer().setHover(hoveringColumnHeader == column);
and the setHover for the renderer is set to true (in my use case).
So my question is
- Shouldn't hoveringColumnHeader be set to null in the onMouseExit method?
Again, I can open a bug report if changes are needed and even include a patch, if needed.
Additionally I can share the Header Renderer that I have implemented if interested (IIRC there was a request for more "Win7 native" headers here on the forums), while obviously not native it does give the a closer "win7" look.
Thanks for the nebula widgets!
Re: Grid - onMouseExit hover question [message #998175 is a reply to message #997912] |
Wed, 09 January 2013 08:59   |
Hi Sven,
Your conclusion sounds correct. File a bug and attach a patch. If you'd
like to share your Win7-Rendering I'm more than happy to add them to the
Grid-Repository.
Just create a bug for them as well and attach the sources. I guess we'll
have to go through the IP-Process for them.
Tom
Am 09.01.13 14:25, schrieb Sean Ruff:
> grid component.
> == column);
> So my question is
> patch, if needed.
> "win7" look.
FUDForum. Page generated in 0.04169 seconds
