How to paginate when HTML preview is triggered in BIRT RCP? [message #1004921] |
Thu, 24 January 2013 01:12  |
Hi!
Newbie to BIRT here so not sure if I'm posting to the right forum; please let me know if I'm doing this wrong.
Anyway, I've read in www.eclipse.org/birt/phoenix/deploy/reportEngineAPI.php that pagination is not possible when using RunAndRenderTask; it should be the separate RunTask and RenderTask to achieve this, correct?
Now, the thing is, we're using BIRT RCP and we cannot implement a separate WebViewer due to our requirements. While I was tracing, however, I noticed that the RCP app uses RunAndRenderTask when I preview the report as HTML. Also, the viewer used is /preview. If I understood the contents of www.eclipse.org/birt/phoenix/deploy/viewerUsage2.2.php right, for me to get the separated Run & Render tasks, I should be using /frameset.
So, my question is, for BIRT RCP, is there a way to paginate the HTML preview without implementing a separate WebViewer? In short, can I somehow force the base RCP to paginate the HTML in HTML preview? If so, how do I get to the separate Run & Render tasks or use /frameset? I'm not very knowledgeable about emitters and I'm still trying to understand how the HTML emitter was implemented.
My question is similar to the one found here: www.birt-exchange.org/org/forum/index.php/topic/16820-how-to-set-pagination-for-reports-formathtml-in-eclipse-birt/page__hl__html%20pagination__fromsearch__1, but, like I mentioned, we cannot implement a separate WebViewer...
Any help would be appreciated!
Thanks in advance!
Re: How to paginate when HTML preview is triggered in BIRT RCP? [message #1005847 is a reply to message #1005248] |
Mon, 28 January 2013 21:22  |
Thanks! Well, I managed to finally set the viewer to /frameset after digging deeper.
What we're actually doing is extending/customizing the BIRT RCP application since we've only begun exploring this type of application. Now, the problem is, I'm going through the RCP codes and although I was able to set the viewer to frameset, I can't seem to set the page range. At the moment, I've been trying to set it in the task as some of the examples online are showing. However, when I try doing it in the RCP, it seems to be disregarded.
Any ideas or suggestions regarding this?
Thanks!
FUDForum. Page generated in 0.15430 seconds
