Home » Modeling » EMF » [CDO] Updating CDO references in XMI Resource
[CDO] Updating CDO references in XMI Resource [message #1005499] Fri, 25 January 2013 12:10 Go to next message
Hello!
I am currently attempting to use an XMI Resource that has been stored as a CLOB in my db but I'm running across reference issues. The XMI Resource loads correctly when its referenced objects have CDOIDLong values but not when the objects have CDOIDTemp values.
I've found that I can update the XMI Resource by listening for a CDOTransactionFinished event, replacing the referenced temp CDOIDs with their corresponding Long values (in the XMI Resource), and then committing the updated XMI Resource to the db (as a CLOB). The problem with this is that it requires a second commit and seems like a very halfway answer to the issue at hand.
Is there an easier way to accomplish this or a better place in the code to update my XMI Resource? I'd really prefer to have everything committed at once if possible.
Thanks in advance!
Re: [CDO] Updating CDO references in XMI Resource [message #1005505 is a reply to message #1005499] Fri, 25 January 2013 12:56 Go to previous messageGo to next message
Hi Jack,
Unfortunately that's a known limitation with server-assigned IDs. A sensible solution would involve to "change the
changes" during the commit process in the server and transport the "outer changes" back to the committing client, which
is currently not supported by the protocol. A couple of times I thought that might be useful but it would require some
funding. If you're that much interested in this possibility you may want to contact me privately in order to discuss
details ;-)
As of CDO 4.1 there's kind of a workaround: You could configure your cdo-server.xml with <property
name="idGenerationLocation" value="CLIENT"/>. By default your local CDOSession would then assign UUIDs (String/byte[])
that don't change during the commit process on the server. But they consume more resources.
Cheers
/Eike
http://www.esc-net.de
Am 25.01.2013 18:10, schrieb Jack Lechner:
> Hello!
> Thanks in advance!
Re: [CDO] Updating CDO references in XMI Resource [message #1005512 is a reply to message #1005505] Fri, 25 January 2013 14:23 Go to previous messageGo to next message
That worked perfectly! Thank you very much!
Re: [CDO] Updating CDO references in XMI Resource [message #1005527 is a reply to message #1005512] Fri, 25 January 2013 23:27 Go to previous message
Am 25.01.2013 20:23, schrieb Jack Lechner:
I guess you tried the client-side assigned CDOIDs. If so you may be interested in this enhancement, too:
396379: [DB] Length of ID column should be configurable
https://bugs.eclipse.org/bugs/show_bug.cgi?id=396379
Cheers
/Eike
Previous Topic:[CDO] NPE at org.eclipse.emf.ecore.util.EcoreUtil.getURI(EcoreUtil.java:2984)
Next Topic:Don't Get It - anyURI and ecore:reference
Current Time: Thu Jul 24 17:57:54 EDT 2025
Powered by FUDForum. Page generated in 0.04778 seconds
