Home » Archived » BIRT » How dataset runs in dashboard(In what order dataset runs in dashboard?)
How dataset runs in dashboard [message #1005339] Thu, 24 January 2013 17:34 Go to next message
I have created a dashboard. In which I have 10 datasets and one 4*4 grid in my design. In each block I have one report, which uses 8 datasets from the available 10 datasets. The rest of the 2 datasets I using as parameters.
My doubt is , when I run my report how / in which order dataset runs in dashboard?
- Is each block of the grid runs at a time ? If so is there anyway we can tune to run parellelly.
OR
- All the reports in dashboard starts to run at same time?
AR
Re: How dataset runs in dashboard [message #1005478 is a reply to message #1005339] Fri, 25 January 2013 10:43 Go to previous messageGo to next message
So, you've created your dashboard in a single .rptdesign file, right? If so, I believe the execution is left to right, top to bottom. What is the issue you're having with how it's currently running? Maybe I'm missing something. Let me know.
Re: How dataset runs in dashboard [message #1005826 is a reply to message #1005478] Mon, 28 January 2013 16:01 Go to previous message
Hi Williams - Thanks for the response.
I am facing performence issue, my dashboard is taking too much time to run. I am trying to tune my queries , after that also I am not finding any good performence.
I got a doubt that if all the datasets in dashboard runs at same time it won't take much time. If it runs one at a time it takes time.
That is why I am trying to understand how the BIRT executes a dashboard ?
AR
[Updated on: Mon, 28 January 2013 16:38] by Moderator
Previous Topic:Web Viewer Fails to Aggregate
Next Topic:How to paginate when HTML preview is triggered in BIRT RCP?
Current Time: Wed Jul 23 07:40:40 EDT 2025
Powered by FUDForum. Page generated in 0.28177 seconds
