Serialization/Formatter Problem [message #1005415] |
Fri, 25 January 2013 06:04  |
Hi!
I have a problem i am not getting around. I created a DSL from an existing Ecore model. I also added an external lexer like in the mwe2 project to make use of sematic predicates. Everthing is working as expected, that means textual model editor and creation of underlying EMF-model and vice versa. The only thing is, that if i serialize an EMF-model, no whitspaces are added between tokens and the formatter does nothing. The whole model is serialized as one big character-sequence.
My question - what is causing this and how to fix it. Did i miss anything in my workflow?
I am using Xtext 2.3.1.
module r3d.targetlanguage.android.Android
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.generator.*
import org.eclipse.xtext.ui.generator.*
var grammarURI = "classpath:/r3d/targetlanguage/android/Android.xtext"
var file.extensions = "java"
var projectName = "r3d.targetlanguage.android"
var runtimeProject = "../${projectName}"
var uiProject = "${runtimeProject}.ui"
Workflow {
bean = StandaloneSetup {
scanClassPath = true
platformUri = "${runtimeProject}/.."
registerGeneratedEPackage = "r3d.metamodel.androidApplicationModel.AndroidApplicationModelPackage"
// registerGenModelFile = "platform:/resource/r3d.metamodel.androidApplication/metamodel/androidApplicationModel.genmodel"
component = DirectoryCleaner {
directory = "${runtimeProject}/src-gen"
directory = "${runtimeProject}.ui/src-gen"
component = Generator {
pathRtProject = runtimeProject
pathUiProject = "${runtimeProject}.ui"
projectNameRt = projectName
projectNameUi = "${projectName}.ui"
language = {
uri = grammarURI
fileExtensions = file.extensions
// Java API to access grammar elements (required by several other fragments)
fragment = grammarAccess.GrammarAccessFragment {}
// generates Java API for the generated EPackages
// fragment = ecore.EcoreGeneratorFragment {}
// the serialization component
fragment = parseTreeConstructor.ParseTreeConstructorFragment {}
// a custom ResourceFactory for use with EMF
fragment = resourceFactory.ResourceFactoryFragment {
// // the Antlr parser
// fragment = parser.antlr.XtextAntlrGeneratorFragment {
// options = {
// classSplitting = true
// the Antlr parser with external lexer
fragment = parser.antlr.ex.rt.AntlrGeneratorFragment {}
fragment = parser.antlr.ex.ExternalAntlrLexerFragment {
lexerGrammar = "r3d.targetlanguage.android.lexer.AndroidLexer"
runtime = true
antlrParam = "-lib"
antlrParam = "${runtimeProject}/src-gen/r3d/targetlanguage/android/parser/antlr/lexer"
// the Ecore2Xtext specific terminal converter
fragment = ecore2xtext.Ecore2XtextValueConverterServiceFragment {}
// java-based API for validation
fragment = validation.JavaValidatorFragment {
// composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
// scoping and exporting API
fragment = scoping.ImportURIScopingFragment {}
fragment = exporting.SimpleNamesFragment {}
// fragment = scoping.ImportNamespacesScopingFragment {}
// fragment = exporting.QualifiedNamesFragment {}
// formatter API
fragment = ecore2xtext.FormatterFragment {}
// labeling API
fragment = labeling.LabelProviderFragment {}
// outline API
fragment = outline.OutlineTreeProviderFragment {}
fragment = outline.QuickOutlineFragment {}
// java-based API for content assistance
fragment = contentAssist.JavaBasedContentAssistFragment {}
// // antlr parser generator tailored for content assist
// fragment = parser.antlr.XtextAntlrUiGeneratorFragment {
// options = {
// antlr parser generator for content assist (and highlighting) with external lexer
fragment = org.eclipse.xtext.generator.parser.antlr.ex.ca.ContentAssistParserGeneratorFragment {}
// fragment = parser.antlr.ex.ExternalAntlrLexerFragment {
// lexerGrammar = "r3d.targetlanguage.android.ui.highlighting.AndroidHighlightingLexer"
// highlighting = true
lexerGrammar = "r3d.targetlanguage.android.ui.contentassist.AndroidContentAssistLexer"
contentAssist = true
antlrParam = "-lib"
antlrParam = "${uiProject}/src-gen/r3d/targetlanguage/android/ui/contentassist/antlr/lexer"
// provides a compare view
fragment = compare.CompareFragment {
fragment = builder.BuilderIntegrationFragment {}
// project wizard (optional)
// fragment = projectWizard.SimpleProjectWizardFragment {
// generatorProjectName = "${projectName}.generator"
// modelFileExtension = file.extensions
// quickfix API
fragment = quickfix.QuickfixProviderFragment {}
Re: Serialization/Formatter Problem [message #1005492 is a reply to message #1005415] |
Fri, 25 January 2013 11:52  |
Hi again!
After troubleshooting the whole day, i found the bug (maybe it is not). Because of my external lexer, i redefined simple terminal rules like whitespaces and did not import the xtext default terminals in my xtext grammar. Because i do not like shortcuts i renamed the WS terminal rule to WHITESPACE. This caused the "formatterTokenStream.hiddenTokenHelper" in "org.eclipse.xtext.parsetree.reconstr.Serializer#60" to have an "wsRule" with null. Thus, no whitespces where put between tokens on serialization. After i renamed the temrinal rule to WS, "wsRule" (from above) is defined and serilization and formatting works well.
So my questions are - is it allowd to rename the WS terminal rule at all in an xtext grammar? Maybe is this a special case, only if one uses an external lexer? Or is this a general bug and should i report it?
Edit: Ok. Now i recognized the function setWhitespaceRule in the FormatterConfig and everthing is clear. Stupid me!
[Updated on: Fri, 25 January 2013 14:26] by Moderator
FUDForum. Page generated in 0.04883 seconds
